Lowering car.
Old Jan 23, 2013 | 07:53 AM
Shrug's Avatar
Lowering car.
OK I have a 1966 Dart 270 wagon.
What is the easiest way to lower it a few inches?
Thanks!
Old Jan 23, 2013 | 09:59 AM
Torsion bar front end?
Old Jan 25, 2013 | 11:49 AM
Shrug's Avatar
Uhm... I actually have no idea. I have never been any good with suspension
How do I tell?
Old Jan 26, 2013 | 10:56 AM
Does it have springs? Google '66 Dart front suspension and look at some pics. If it's torsion, it's easy as pie.
Old Jan 26, 2013 | 01:05 PM
All A bodies have torsion bars. You can lower it some Maybe two inches. The suspension will have a tendency to bottom out. PUT the car up on jacks to adjust them. Any more than that and you need to have custom spindles made
Old Jan 27, 2013 | 11:35 AM
Chryco Psycho's Avatar
First soak the adjusters in penetrating oil , Make Sure the weight is off when you loosen the adjuster bolts so they do not strip & the cars falls on you , count the number of turns you undo each side so you get it even , your toe in will change as it is lowered so you Have to reset that as a minimum or have the wheels re-aligned .
The rear can be lowered with lowering blocks between the spring & diff , check the pinion angle , you can correct that also with angled lowering blocks if it is off .
Old Jan 27, 2013 | 12:01 PM
Yessir! You can effectively lower your car in two hours this way. I had the back of my Fury down three inches via blocks, but I knew nothing of how to drop my front. Then someone told me about the torsion screws and about an hour later, the car was in the weeds.
Old Feb 2, 2013 | 07:04 PM
Shrug's Avatar
I appreciate the info. After I finish the heads this week, I will crawl underneath and look around!
Old Feb 19, 2013 | 04:28 PM
Thecollector's Avatar
that is interesting to know how easy it is to lower the front. Would you need to re align the car after that though?
does any company sell lowering blocks specific for a body cars? or is it a make your own type deal?
Old Feb 19, 2013 | 05:10 PM
mikerp76's Avatar
autozone carries them. yes you will have to get the front realigned for both toe and camber.
Old Feb 19, 2013 | 05:19 PM
Nice, that is good to know thanks, Looks like once i have mine running ill be lowering it soon after, id be intrested to see some pictures of before and after from the OP, i know i will be snapping a few!
Old Feb 19, 2013 | 05:55 PM
mikerp76's Avatar
i would also think about putting a small section of tubing at the back of the k frame near the oil pan just to make sure that the pan is protected from bottoming out on the road.
Old Feb 19, 2013 | 09:00 PM
very good idea! thanks for the idea. id hate to have to buy a new oil pan
Old Feb 20, 2013 | 05:39 AM
mikerp76's Avatar
i'm thinking of doing that on my car the pan sits about 1/4" below the k frame. and the bottom of the pan has a few dings in it already.
Old Feb 20, 2013 | 08:55 AM
you lowered yours alredy or is that with stock hight? I'm in Maine land of potholes and frost heaves so lowered cars are not very common.
Old Feb 20, 2013 | 05:48 PM
mikerp76's Avatar
it's semi stock height. it was lower than it is now when i first got it. and it bottomed out everytime i went over a speed bump
kgarber
Nov 2, 2019 08:58 PM
patricklyle77
Sep 13, 2010 08:45 AM
kgarber
Aug 30, 2009 05:08 PM
Monacoman
Aug 13, 2009 10:00 PM
patricklyle77
Jun 13, 2007 09:47 PM
