Residual pressure elimination
Jul 20, 2022 | 10:04 AM
Customer car 1970 Demon street/strip.
Just installed a new manual disc brake conversion brake kit from The Right Stuff.
Front brakes and master cylinder.
Installation was smooth.
*** Only propo valve in system is a manual for the rear brakes ***
Retained rear drums
Bled system several times via gravity, back bleed, then pressure bleed.
The front calipers retain pressure, thus dragging the rotors. I crack the bleeder, a little spurt, then the rotor turns freely.
Pump the brakes a couple of times and they lock up until I open the bleeder to get that little spurt.
Calipers are plumbed direct from M/C into a T then to each wheel.
Rear drums do not lock up.
Any ideas ?
The Right Stuff is now owned by Restoration Parts Unlimited and they offer zero tech assistance on their website.
Reply 0
Jul 20, 2022 | 12:21 PM
D -
Off the top of my head: is there a proportioning valve, and was it set up correctly?
Reply 0
Jul 20, 2022 | 01:53 PM
Reply 0
Jul 20, 2022 | 04:51 PM
Is the piston in the master cylinder releasing all the way? Just wondering if the rod on the brake pedal needs to be shortened a little.
Reply 0
Jul 21, 2022 | 08:53 AM
I Agree with five points..... Also double check the flex hoses to make sure they are not working as a one way check valve... If that's all good I would say you have to remove or change to a lower residual valve setting.
Reply 0
