Traction Questions
Old Mar 23, 2016 | 11:04 AM
DodgeFather's Avatar
Traction Questions
Hello ! I have an 86 D150 2wd. 360 automatic. I plan on warming up the 360 a bit & the trans has a fresh TCI manual shift kit that shift crazy hard(maybe to hard ?).
I pulled the rear cover off the rear end to change oil & inspect the gears. I noticed the oil was dark purple/blue ? & checked for ratio stamping & found a "391", i do believe the gears have been changed possibly the same time the trans was done ? Previous owner has changed cell # so can't verify for sure but i don't think 391 was offered in this truck but i could be very wrong. I'm having horrible traction problems even when im on a slow roll & nail it. I don't want to go all pro suspension just for what I'm going to be building so i was wondering if there is a old "slapper" style traction bar for Dodge trucks ? I see them for cheby & Ford. Any tips would be very much appreciated:
Old Mar 23, 2016 | 04:53 PM
Back in the 80s I had a 77 short box with a 360 and 410 gears. Traction was a problem but what worked the best was moving the spring hangers up on the frame and leveling out the truck.
A good set of tires and 100lbs of weight in the box helped too, I also clamped the front half of the leaf springs and cut the straps off the rear.
Good luck, that's all I've got.
Old Mar 23, 2016 | 04:59 PM
Thanks, every tip helps. Didn't think traction would be a issue because of the basic weight of the truck but it sure does.
Old Mar 23, 2016 | 07:04 PM
Bolt in 2 parking stops in the far rear of the bed....
Old Mar 24, 2016 | 03:25 AM
RacerHog, what are parking stops ?
Old Mar 24, 2016 | 12:36 PM
I'm assuming he is referring to the cement parking stops that you find in parking lots
Old Mar 24, 2016 | 12:43 PM
Yeah, i feel like a dumbazz Lol. Thought about those cement air dam killers after i asked the question.
Old Mar 24, 2016 | 01:18 PM
Yep... Those are the ones.....
Don't laugh... It works....
Also a good Wide Street Drag Radial might give it some better bite. But I'm not sure how much tire fits under those trucks?
Old Mar 24, 2016 | 01:24 PM
I bet it does work, that's a lot of weight ! Just means i have to add a few more pony's to pull it. Im really liking what i see with the 408. Any pro's or con's ?
Old Mar 24, 2016 | 01:26 PM
I have 255/60/16 rears
Old Mar 24, 2016 | 04:15 PM
408's make some good Pony's... I like them.. Would go great with that trans you have at the moment, I think....
Old Mar 24, 2016 | 04:18 PM
Food For thought....
http://www.summitracing.com/search/P...ize/255-50-16/
Old Mar 24, 2016 | 04:19 PM
That's what i was hoping you would say are the 391 gears a keeper ?
Old Mar 24, 2016 | 05:13 PM
Yes, ....and tire smoke big time!
Get a limited slip now! ......Or smoke em! And be happy.
Old Mar 24, 2016 | 05:27 PM
She lights up both tires pretty good now so i can only guess what a 408 will provide.
Old Mar 24, 2016 | 06:54 PM
Oh ya... 3.91 will be a good gear...But I'm with Iowan... Going to need a Sure Grip for sure..
Oh and a couple Parking Stops bolted in the bed....
Pistol pete
Nov 13, 2015 10:22 AM
mack23
Jul 13, 2015 10:35 PM
1968newport
17
Dec 22, 2013 02:04 PM
scotty
Sep 22, 2011 06:43 AM
scampdude
Feb 10, 2011 03:15 AM
