72' Dodge Coronet Custom starting/ wiring problem?
Having problems starting my car. I replaced the starter alternator and ground cable a battery with new terminals and it started for a little bit with no problem and now it has to be jumped every time I start it.
someone throw me a bone here
Jumped as in the battery is dead? or Jumped as in at the starter solenoid?
If it is at the solenoid. Check the Neutral safety switch.
Also. Check the yellow wire on the starter Solenoid and see if it ig getting power when you turn the ignition switch into the start position?
No it wants to start but what happens is it doesn't so I have to give it a jump it's like the battery is low on charge and then it'll die while I'm turning the ignition over
duster fanatic
Jun 29, 2013 11:07 AM
