72' Dodge Coronet Custom starting/ wiring problem?
Old Jan 16, 2022 | 01:19 PM
Walshkris36's Avatar
Having problems starting my car. I replaced the starter alternator and ground cable a battery with new terminals and it started for a little bit with no problem and now it has to be jumped every time I start it.
someone throw me a bone here
Old Jan 16, 2022 | 01:39 PM
Bad ground?
Old Jan 16, 2022 | 01:43 PM
Bad ground?
Well I replaced it already.
Old Jan 16, 2022 | 01:50 PM
THe starter and alternator are new as you can see and the ground and terminals
Old Jan 16, 2022 | 05:18 PM
Jumped as in the battery is dead? or Jumped as in at the starter solenoid?
If it is at the solenoid. Check the Neutral safety switch.
Also. Check the yellow wire on the starter Solenoid and see if it ig getting power when you turn the ignition switch into the start position?
Old Jan 16, 2022 | 06:05 PM
Jumped the battery. It acts like it doesn't hold a charge. I will try tomorrow to see if the yellow wire on the starter solenoid is getting power
Old Jan 17, 2022 | 05:54 PM
OK.... So every time you go out to start it,,, it will not turn over and the battery is dead?
Old Jan 17, 2022 | 06:05 PM
No it wants to start but what happens is it doesn't so I have to give it a jump it's like the battery is low on charge and then it'll die while I'm turning the ignition over
Old Jan 19, 2022 | 12:58 PM
Time to Load test the battery and see if it has 750 CCA like the label says
hkestes
Sep 7, 2018 08:51 PM
chuck1934
Dec 9, 2014 08:56 PM
duster fanatic
Jun 29, 2013 11:07 AM
jdewoskin
Jun 8, 2010 04:14 PM
Kinger1421
Jan 23, 2010 04:59 PM
