Alternator swap
Old Aug 20, 2013 | 08:35 PM
1968newport's Avatar
Alternator swap
Ok. I am replacing the stock 60 amp alternator with a larger 130 amp one. I am re-wiring car with a painless harness. Is there anything I need to know so I don't fry anything?
Old Aug 21, 2013 | 08:29 PM
moe7404's Avatar
the AMP gauge in the dash my not hold up. i have seen people just wrap a wire around the two posts, but that would take the AMP gauge out of the deal. if you have to do that just get a volt meter. most of the new cars use volt meters and seam to do the job fine.
Old Aug 22, 2013 | 06:05 AM
Excellent. Tha you very much. Volt meter it is.
Old Aug 22, 2013 | 10:01 AM
Make a complete separate wiring harness for the alt..
Old Aug 22, 2013 | 12:09 PM
And use BIG wire. I'd use AT LEAST no6
Old Dec 12, 2013 | 09:57 PM
70newport's Avatar
I am assuming in doing the painless kit you are eliminating the bulkhead connector. If that is not the case make sure you do so. And if you are running the smaller voltage regulator that came from factory on the 68 newport upgrade it to the bigger one. I cant remeber what the ratings are but the smaller one will not handle a high output alternator well and you will more than likely explode a battery..... like I did.
give that a read. Very good info for any mopar guy.
Old Dec 20, 2013 | 04:11 PM
PURPLE HORONET's Avatar
Get a one wire alt,, the best way to go..
Old Dec 21, 2013 | 07:23 AM
Yep, some good advice, here. I have a 105 amp in the rig and I went voltmeter--no issues whatsoever. also, use the fat wire, as mentioned. The bigger the better. you don’t need 0 gauge amp wire, but something nice and thick to ensure no resistance and heat.
Old Dec 21, 2013 | 09:40 AM
You should use a 4 awg wire from the alternator to the battery.
Old Dec 23, 2013 | 08:33 PM
moparted's Avatar
why do you need 130 amps?
mikeynags
Jun 16, 2009 08:19 PM
mikeynags
Jun 16, 2009 06:31 PM
panda!
Jun 4, 2009 11:54 AM
roadrunnerrelic
Nov 7, 2008 06:56 PM
rabys
Sep 14, 2008 04:05 PM
