Backup/interior lights
Old 08-31-2013 | 05:02 PM
dsikkema's Avatar
Backup switch
My backup lights are not working so i removed the switch at the base of the steering column (68 Fury III)... can someone tell me if the red sliding mechanism on the back of it is supposed to attach to something?
Thanks
Old 09-06-2013 | 06:34 PM
dsikkema's Avatar
Can someone please tell me the part that is supposed to move the toggle... Doing my head in!
Old 09-06-2013 | 08:48 PM
Back up light switch is on the trans.... Violet wire....
I think??????
Old 09-06-2013 | 09:02 PM
dsikkema's Avatar
pics attached.
the switch works... as the red spring mechanism slides it makes contact with the wires and the backup lights come on, i can do this with my fingers. just cant figure out what actually moves the mechanism when bolted onto the base of the steering column?
is there an arm or something i am missing?
Attached Thumbnails Backup/interior lights-img_0884.jpg   Backup/interior lights-img_0885.jpg
Old 09-06-2013 | 09:08 PM
dsikkema's Avatar
the issue is with this switch, not the trans. as i said i can get it to work with my fingers.
Old 09-06-2013 | 09:35 PM
I was looking for a break down of the column, but I could not find one.....
I also dont see a bracket listed for it.....
Maybe some one else has a break down for us....??????
dsikkema (09-06-2013)
Old 09-06-2013 | 09:48 PM
dsikkema's Avatar
thanks racerhog.
is anyone else familiar with this set-up?
Old 09-23-2013 | 04:32 AM
dsikkema's Avatar
the part i need is 2883211. does anyone know where i can get one?
Old 09-23-2013 | 05:29 PM
Wow...Shoot a picture of that installed, when you get a chance.... That ones got me messed up......lol
Keep us posted....
Old 09-23-2013 | 08:59 PM
Silverick's Avatar
Keep us posted....
X2!
On my '68 Fury, the back up lights don't work either and other than checking the bulbs, I have never investigated....
Thanks!!
Old 09-23-2013 | 10:20 PM
dsikkema's Avatar
Here are some pics I found of what it looks like installed. I have the manual for the 68 Fury and apparently to get these out of the slot originally you must brake them and they are unable to be reused.
Since, to the best of my knowledge, they are not reproduced this makes them extremely hard to come by in working condition (or even at all)!
I am going to attempt to use a bolt or something in its place and hope it works.
if anyone knows where I could get this part please let me know.
ill keep you posted.
thanks
Attached Thumbnails Backup/interior lights-5402450-newcolumn1.jpg   Backup/interior lights-5400193-back-uplampswitch.jpg
Old 09-23-2013 | 10:29 PM
dsikkema's Avatar
If anyone else is having issues with their back up lights, I would check this first. it seems to be quite a common problem but very little information out there on it!
I believe this is an older type set-up also and the newer models run through the neutral safety switch in the transmission.
belvedere383
10-08-2014 07:47 AM
josehf34
09-28-2013 12:58 PM
1966charger
04-22-2012 09:27 PM
chiefgtx
09-26-2009 01:07 AM
