Ballast Resistor Temp
Old Oct 11, 2012 | 07:10 PM
jar84203's Avatar
Member
I know a ballast resistor is supposed to get hot during low speed operation to increase resistance, but how hot is it supposed to get? With the ignition on without the engine started, mine is too hot to touch. 71 Duster 225ci with electronic ignition conversion.
Old Oct 11, 2012 | 08:38 PM
Better keep a couple handy then. Sounds like you have some resistance on the primary side of the ignition system. 440 will chime in later on with all the details to check.
Old Oct 11, 2012 | 09:09 PM
Too hot to touch is perfectly normal WHEN RUNNING. It IS possible that you have the wrong coil, or a damaged coil, but in the case of a partially shorted coil, a high speed miss, especially under load is the norm.
NEVER leave the key on for long periods without the engine running. I don't know on the Mopars if it will hurt the ECU, but it can burn up coils and ballasts
Old Oct 12, 2012 | 05:20 AM
Gorts 5th's Avatar
Smile
i have had one get so hot that it started too sizzle it burnt the paint on the firewall turned out to be a bad coil
Old Oct 16, 2012 | 11:47 PM
jar84203's Avatar
Member
I'll check the primary side resistance and let you know what I find.
Old Oct 24, 2012 | 10:24 AM
Nadir Point's Avatar
I always use a longer screw with a spacer to mount it offset away from the firewall a half inch or so to help it cool. Haven't had one go bad yet.
dgbcharger
Nov 24, 2014 07:35 PM
74Runneer
Jul 30, 2013 07:45 AM
440GTXguy
Apr 20, 2013 10:14 PM
nesparky
Oct 13, 2009 04:33 PM
Mixmastermerrill
Aug 14, 2008 01:36 PM
