Clarification for Electric Ign.
Old Oct 21, 2014 | 11:22 AM
Robert Weaver's Avatar
Question Clarification for Electric Ign.
The 2 wires coming from the w. Harness to the coil, is the power/hot wire suppose to go to the positive or neg terminal on the coil? I've seen where the hot wire goes to the neg for ground. Just confused.
74 charger se 318 2-bbl
Old Oct 22, 2014 | 06:42 AM
62Furious's Avatar
here is an "old school" diagram from an early Direct Connection manual. Hope this helps.
Old Oct 22, 2014 | 06:43 AM
62Furious's Avatar
Old Oct 22, 2014 | 07:20 AM
K thanks. But should the hot wire go to the neg on the coil?
Old Oct 22, 2014 | 08:31 PM
moparted's Avatar
no
Old Oct 24, 2014 | 07:12 AM
Hot wire to + side of coil...
Neg wire to the - side of coil goes out to the Dist.
Old Oct 24, 2014 | 08:28 AM
K thanks. Would a weak coil or alternator make the car not run or run 1-3 secs then stop? Or cause a weak spark?
Old Oct 24, 2014 | 10:14 AM
Yes.... Minimum of 10.5 volts is required to have the system run at all.
No with that being said... One the car is running and if the battery has lets say 11.5 Volt it will run on just that till the voltage drops making the ignition to weak to keep it running... So yes you are rite in your assumption...
If the fuel is no good? that might be what causing it to stall? If its not the ignition loosing its voltage?
Old Oct 24, 2014 | 12:21 PM
Any way of checking the alternator without the car running? Also, there's 1 Braided Ground Strap on the firewall, where should that be grounded to?
Old Oct 24, 2014 | 03:23 PM
Pull the alternator and take it down to your local Parts house that has a bench tester... They can run it for you and see if it's any good......
That strap from the fire wall goes to the engine....
Old Oct 24, 2014 | 05:39 PM
K thanks, right now the ground strap is attached to the firewall to the manifold where the coil bracket is.
Old Oct 24, 2014 | 07:05 PM
That will work just fine...
jeffz
Jul 29, 2013 01:08 PM
craveman
Jul 5, 2011 08:51 AM
SixFoPolara
Aug 3, 2009 05:08 PM
heminate
Apr 2, 2008 08:42 PM
polyhead_318
Nov 23, 2007 01:12 PM
