Drivers side window regulator assembly 70 RoadRunner
Old Oct 24, 2015 | 05:05 PM
WI70rr's Avatar
I am in need of one my window is a bear to put up or down. Any leads would be appreciated. I have googled the heck out of this an nothing....
Thanks
Old Oct 24, 2015 | 07:00 PM
Check all the felt in the channel and make sure it is in it's place.....
If all is good there, lube the felt and channel with some silicone spray.... Also lube the window regulator with some spray lubricant.... That should help it a lot. Also make sure to lube all the rollers and channels..... And dont forget to do the vent glass hardware also.....
Old Oct 24, 2015 | 10:00 PM
WI70rr's Avatar
She is pretty well gone looking for a new one.
Old Oct 25, 2015 | 12:09 AM
On several cars I have taken the clutch mech or what you call it from another reg to fix a hard to turn one
Old Oct 25, 2015 | 08:18 AM
http://www.classicindustries.com/sho...arts/?q=mm1088
fletchy38
Jun 16, 2012 09:31 PM
fletchy38
Jun 16, 2012 07:37 PM
moparjohnson123456
Jun 14, 2011 01:36 PM
68 Sat
Mar 29, 2009 03:56 AM
1969GTX
Apr 5, 2008 06:20 PM
