electrical gremlins
Old Oct 28, 2017 | 07:46 AM
Farmertan's Avatar
electrical gremlins
why would my voltage regulator keep getting hot and smoking?
Old Oct 28, 2017 | 07:52 AM
Bad Grounds.....
Or Wiring and connections are old and corrosion has set in.
Here is some good reading when you have a chance... http://www.madelectrical.com/electrical-tech.shtml
Old Oct 28, 2017 | 08:25 AM
Farmertan's Avatar
checked all that already unless I missed something voltage regulator seems to be grounded good
Old Oct 28, 2017 | 10:12 AM
Drag Pak's Avatar
Cheap aftermarket/offshore voltage regulator? Check charging voltage to make sure you are not going to blow up your battery!
Old Oct 28, 2017 | 11:04 AM
Farmertan's Avatar
I had 14.69 at the battery and 14.8 at the alt stud at a fast idle say 2000 rpm
Old Oct 29, 2017 | 03:42 PM
Drag Pak's Avatar
Does it droop immediately after startup and return to 14.9 or a steady 14.9
Old Oct 29, 2017 | 04:26 PM
Farmertan's Avatar
Steady I think I'll have to recheck tomorrow
Old Oct 29, 2017 | 05:08 PM
Farmertan's Avatar
By the time I start it and put the meter on it it's steady
Old Oct 29, 2017 | 05:39 PM
Not to interrupt.....
These work pretty darn good.... https://store.alternatorparts.com/partnoc8313.aspx
Old Oct 29, 2017 | 06:33 PM
Farmertan's Avatar
Ya but I want to find my problem before I smoke my whole harness. are those better than the old points style voltage regulators?
Old Oct 30, 2017 | 11:05 AM
Oh... I see... Your using the early style Voltage Regulator ? Before 1967?
Old Oct 30, 2017 | 12:28 PM
Farmertan's Avatar
Ya 68
Old Nov 2, 2017 | 02:04 PM
Those will get hot to the touch...... Check the wiring about 4 inch's away from the reg. and see if it still feels hot?
Old Nov 2, 2017 | 03:49 PM
Farmertan's Avatar
It actually started to smoke
Old Nov 2, 2017 | 08:15 PM
So you have a good battery, it's been verified, correct?
your not trying run your junk with a dead battery are you?
Old Nov 2, 2017 | 08:24 PM
Don't be offended my mopar junk makes 650hp on pump fuel.
Old Nov 3, 2017 | 03:50 AM
Farmertan's Avatar
Brand new and charged up
Old Nov 3, 2017 | 10:54 AM
You cleaned the regulator ground and the body to engine ground also? Rite !!
Old Nov 3, 2017 | 11:10 AM
Farmertan's Avatar
Yep
Old Nov 3, 2017 | 11:27 AM
Ok... Question... The new regulator gets warm and smokes?
If the answer is yes... That is somewhat normal to some extent.. But once all the newness burns off. It should not smoke anymore.
But the regulator you are using dose work all rite? Or is it giving you a charging issue?
Old Nov 3, 2017 | 12:47 PM
Farmertan's Avatar
I know something's not right cuz I'm getting 18 volts at my coil
Old Nov 3, 2017 | 03:23 PM
Hummmmm... The 14,9 I could have lived with.... But 18.0 Volts ? That is way to much, That will hurt stuff..
Sounds like the regulator is not getting a signal back to release the charge....
Or the regulator might be stuck in "polarization mode".. If I remember rite.. You have tp polarize them when you first install them...
Not sure why you got 18.0 volt to the coil? That voltage should be cut down by a ballast resistor?
Might also try checking and/or adjusting the contacts on the regulator... Might just be out of adjustment range.
Panderz
Mar 30, 2017 09:48 PM
ef8340
Oct 5, 2008 06:09 AM
64fury
Mar 9, 2008 02:02 PM
TCPMeta
Mar 28, 2007 04:27 AM
