Hazard Lights Question 66 Polara
Old Jul 30, 2013 | 10:40 AM
Mr. Fix it's Avatar
Hi there, here's a newbie question.
Is there hazard lights on my 66 Dodge Polara???
Old Jul 30, 2013 | 08:03 PM
Ottawaguy's Avatar
No hazard lights on 1966 Dodge Polara. I had a 1966 Plymouth Fury and it didn't have hazard lights either. I believe either 1967 or 1968 were the first year with hazard lights as standard equipment.
Old Jul 30, 2013 | 10:57 PM
You could easily add them if you want, there used to be aftermarket kits to do so and I'd bet you could scare one up on "the bay."
Also, you could use a dash mount 4x switch out of a 67--69 car such as came in my Dart. These are a 4 terminal switch, such that when off, all terminals are isolated, and when on, all terminals are connected together.
The way it works, is you feed the 4x flasher unit from a fused source, run the output to one switch terminal.
Take one terminal and feed it to the cold side of the brake light switch which is going into the column turn signal switch.
Then find the left and right FRONT turn signal wires, and hook the remaining two terminals to them.
So the way this works is, when on, the switch takes the output of the flasher and feeds it to the front left/ right lamps, and to the brake lights going through the (centered) turn signal switch, and to both rear lamps.
Old Jul 31, 2013 | 03:43 AM
Mr. Fix it's Avatar
I'm planning to revamp the electrical system this winter so this will get added to the list of "things to do"
Thanks very much!
moe7404
Oct 13, 2014 06:11 PM
98 SNAKE EATER
Apr 10, 2013 07:53 PM
1966charger
Apr 22, 2012 08:27 PM
dorseyh
Aug 12, 2009 10:52 AM
