Internal regulator alternator conversion
Old Apr 13, 2015 | 05:11 PM
josehf34's Avatar
I've been having over charging problems with my 74 fury stock alternator, I replaced voltage regulator two times but not success. Today while checking the Field terminals I heard a "click" noise from the alternator and it stopped charging.
I'm not sure if I want to rebuilt it (If I do, will be the second time) so I was considering to upgrade for a 80 amp or 100 amp unit with an internal regulator. I've been looking for guides about doing this conversion but I've a couple doubts:
-Should I buy an 1 wire or 3 wire alternator?
-A GM case style alternator will fit on the mopar brakets?
Old Apr 14, 2015 | 02:14 PM
Rooty's Avatar
I installed a Denso on my 383 block. 95 amp, 3 wire although you don't have to use the charge light wire. Fit perfectly and very compact. Had no problems in the last 3 years. Make sure what ever you buy to keep the pulley in mind - I ordered mine with a v-groove but you can get serpentine as well.
Old Apr 14, 2015 | 03:45 PM
josehf34's Avatar
Looks great, my unique concern is that if a GM case style alternator will fit on a stock mopar alternator bracket, does it fit?
Old Apr 14, 2015 | 04:16 PM
Rooty's Avatar
No, not without mods. It's because of the mounting tabs which have to be a certain orientation for direct mounting ie: 180, 120 etc degrees apart. Also the depth of the unit may be an issue for fit and aligning the pulleys.
Old Apr 14, 2015 | 06:25 PM
josehf34's Avatar
mmm so I think the better option is to use a mopar alternator, or, is there aftermarket brakets for install the GM alternator on my fury?
Old Apr 14, 2015 | 09:32 PM
DDodger's Avatar
I don't keep up on all the aftermarket stuff. If you can figure a way to mount it, you can make it work.
But.........does the 74 have a "full current" ammeter, or external shunt? This is an issue when wanting to add great big alternators
Old Apr 14, 2015 | 09:39 PM
josehf34's Avatar
Well my 74 have an ammeter but is broken so I installed an additional sunpro ammeter. I think I'm going to buy a Tuff Stuff 80 Amp alternator and two extra universal brackets to see which one fits
bremereric
Nov 29, 2011 09:15 PM
murry
Apr 14, 2011 04:16 AM
bremereric
Mar 23, 2011 01:24 PM
69POLARA383
Oct 9, 2010 06:03 AM
