No ignition
No ignition
Hi guys.
Yesterday I left the car on the garage, everything fine but today the car didn't start. I think the problem is electrical because I already check the fuel delivery and everything is ok, I checked IGN 1 and IGN 2 and both lines has power but the car doesn't want to start
Sorry I miss some things
Car: Plymouth Fury 1974
Type of ignition: Electronic HEI
Ballast resistor bypassed
Ignition Coil: Mallory 58000 V
No MSD, self contained distributor. I'm using the stock ignition module just for wire the distributor ground.
Thats all
Thats all
Power to the + side of the HEI ?????
Also make sure the 3 prong plug nearest the cap is plugged all the way in.
If those are good... You ether have a bad coil or the Module is bad... To test them that have to use a DVOM meter and follow the instruction for testing to the T...
If the distributor is gone, which can be a good option for a HEI setup? maybe MSD or self contained distributors are junk?
This might Help....
http://forums.carcraft.com/70/661769...odule-testing/
Right now I'm a bit confused. I was checking the distributor wiring (don't touch anything). I cranked the engine and fired up at the first time, I tried again four times more and fire without problems, let her idling 15 minutes and fire up again without problems.
what might have caused this?
Does my distributor is "fine" or is just crap? (is exactly the posted one)
Yes, I was checking if I got spark but when I cranked the engine to check If I was getting spark, the car fired up, since this I haven't had problems, today the car always has fired at the first try.
If I remove the distributor cap, how can put it again without setting the initial advance again?
a.johansson84
05-27-2012 03:30 AM
GMdude
07-09-2009 04:42 PM
