No power to dimmer switch
Old Jul 31, 2019 | 01:35 PM
  #31
75w200military's Avatar
B2 is where the headlights work if I put the military switch on B1.
Old Aug 2, 2019 | 06:32 AM
  #32
My friend, I'm sorry, I just dont see or cant get my head around were to guide you at this point. Most of what you have done looks correct per say.
I'm a little hesitant to say you might be chasing a relay on the Aux side of the wiring as the problem?
Just an FYI, And this came from a pretty good source of mine. This area M880 came with Civilian wiring and the (Black Out) was added in at the Motor Pool level, so i was told that is why it's so hard to fine and wiring info because some of them where install as it was understood by whom ever performed the install. Just a thought.
Maybe someone might jump in that could shine a little light on the subject?
Best of luck... Keep us posted if you get it fix !!!!!
Old Aug 2, 2019 | 12:24 PM
  #33
Thanks for the reply, that makes total sense. However, the wiring does not. 🤪 I hope I can figure this out soon. Doesn't seem like anyone else is too interested in helping, but I appreciate your time.
Old Aug 2, 2019 | 01:17 PM
  #34
It's not that nobody is intrested but you have an unusual problem. A military vehicle takes a military mechanic.
Old Aug 2, 2019 | 03:38 PM
  #35
What happens if you piggyback the running lights with the headlight wire? Dose everything work then?
https://www.autozone.com/ignition/el...ect/600429_0_0
Old Aug 4, 2019 | 07:44 PM
  #36
I thought about trying that, but if I remember right the green or black wire has to be on that rear corner post for anything to work. I'll check tomorrow. Thanks
Stuntman_Bill
Sep 25, 2023 06:55 AM
val1550
Jul 18, 2013 12:17 PM
val1550
Jun 19, 2013 08:37 AM
zberg
Apr 13, 2012 05:22 PM
Satellite72
Apr 9, 2011 11:11 PM
