Old to new or new looking Part3
Old Jan 20, 2015 | 04:03 PM
Rooty's Avatar
It was time for a first look at the gauges mounted in the housing to see if spacing between them appeared OK. At this point if there were any corrections to be done, now was a good time. As stated earlier, I added two LED's for "high beam" and oil warning light should the pressure drop below 18 p.s.i. I will have to remake the foam pieces that sit on top of the turn signal light boxes and I think I'll attach them to the back of the trim bezel. It may seem that there are a lot of connections for the gauges but many are common to all and can be wired in parallel. There will be an 8 pin Molex connector wired on the back for the various wires so disconnecting the speedo head will be a snap. Using a male/female connector makes wiring so easy and produces a "plug and play" situation.
Attached Thumbnails Old to new or new looking Part3-hpim3765.jpg   Old to new or new looking Part3-hpim3766.jpg   Old to new or new looking Part3-hpim3771.jpg   Old to new or new looking Part3-hpim3772.jpg
Old Jan 20, 2015 | 04:13 PM
I like IT...
Rooty
Jan 22, 2015 07:30 PM
Rooty
Jan 22, 2015 04:20 PM
Rooty
Jan 21, 2015 08:51 PM
Rooty
Jan 20, 2015 07:56 AM
