Signal Switch?
Old Sep 4, 2011 | 12:46 PM
Leem's Avatar
Signal Switch?
Hi all,
Somebody must have had this problem before. When car turns on, left signal indicator lights up on dash...not blinking, just steady green. The left front signal light goes on and stays on, again, not blinking just steady. Right hand signal works fine. Flasher appears to be working fine. Now, I took the flasher out to see what would happen. Light goes on on exterior and dash light as well for left hand signal. Ground appears to be fine as well. Am I looking at a signal switch here?
Marty
Old Sep 4, 2011 | 03:49 PM
Wiggle the 4 way flasher switch a few times, make sure it's off, and try removing BOTH flashers.
The only power going INTO the signal switch is---
"regular" flasher power
4 way flasher power
power from the brake light switch when depressed
Next try unhooking the connector to the signal switch at the column
And ya, whut 'er we workin' on? 41 Ferd? 54 Stupidbaker? 71 Dogede?
Old Sep 4, 2011 | 04:21 PM
Leem's Avatar
I will try that in the morning. Frustrating because it started yesterday morning, then went away and reutrned this morning. Oh...it's a 70 Roadrunner.
Marty
Old Sep 4, 2011 | 04:51 PM
Leem's Avatar
OK, I actually went out and tried wiggling the 4 way...nothing changed. Then I turned the 4 way flasher on and wigled it. After shutting off the 4 way flasher, the problem was gone. Lol...I kind of think it will return though. I will keep posting as i either solve the problem or not.
Thanks,
Marty
Old Sep 4, 2011 | 07:20 PM
Great. At least now you know what to watch for. I'd guess that if the switch was not "bumped" part way on, you have a signal switch starting to fail.
Old Sep 5, 2011 | 11:14 AM
Leem's Avatar
Update,
As I expected, the left signal light came on again. Turning on the 4 way flasher would eliminate the problem until next time I had to start the car. This time, I disconnected the 4 way flasher and the signal light does not come on when starting. I will check over the next couple of days to see if this has eliminated the problem. Whole lot easier to change the flasher than the switch...lol.
Marty
Old Sep 5, 2011 | 03:09 PM
Well the flasher is NOT the problem. It's in the switch.
As I outlined earlier, there are three power sources going into the switch:
the flasher, the 4 way flasher, and when the brake pedal is pressed, power from that circuit.
So if the switch is centered, 4 way switch off, and no power to the brake lights, then you have a signal switch problem.
Old Sep 6, 2011 | 05:26 AM
Leem's Avatar
Yes, yes...I understand what you mean. And I will be replacing the switch...but not til I take the car off the road next month. For now, the temporary solution is adequate.
Thanks,
Marty
Old Sep 8, 2011 | 06:46 PM
scotts74birds's Avatar
Your root problem is a bad ground. DC is an insane animal when it loses ground! The rule is.....when it dont work, check power. If it works weird, check ground! Your original question pointed me to ground. My Ram did the same thing after I put in a trailer pig-tail. Result....bad ground! Did you also notice that your front signal may have lightly glowed too?
Old Sep 8, 2011 | 08:01 PM
Sorry, but not this time. What he's got there is some of the contacts in the signal switch are broke/ out of place/ worn. He already proved it by fooling with the 4x switch
There is no ground problem that can cause all this all at the same time.
Old Sep 9, 2011 | 05:34 AM
Leem's Avatar
Yes, I did check the ground, and it was okay.
Marty
Old Sep 10, 2011 | 07:02 PM
Rats! Well, nobody bats 1000!
MapleMan
Aug 19, 2015 08:27 AM
homebrood
Jul 4, 2012 07:17 AM
Arbiter343GS
Oct 31, 2011 08:44 AM
dorseyh
Aug 22, 2009 10:27 PM
69SatSport
May 2, 2009 07:36 AM
