spark issues
Old Oct 28, 2025 | 06:08 PM
denis280's Avatar
spark issues
HI! all new here, the wife when for gas and camp.she forgot to put the cap back on, was raining all weekend. back home it was running bad, 3 days after sitting still, was starting (turning) but not running. Water in gas tank. empty all of it. changed fuel filter blead the line. noticed the fuel pump was leaking around the cup. changed the fuel pump.cleaned out gas and water in float. Now when new gas got in it, started run and died, changed ballast resistor, No luck. noticed a green wire from the ballast was cut. fixed it. then noticed they accelerator pump not pushing gas in, ordered new carb. and replaced it with old gasket from the previous, changed control module. coil. she starts run for 10 min. then stop. run fine start cold, 1979 doge b100 318 2bbl
Old Oct 30, 2025 | 08:51 PM
Is there fuel in the carburetor when it stops running?
Old Oct 31, 2025 | 08:00 AM
So it runs until the choke opens and then it dies?????
Old Nov 7, 2025 | 12:56 PM
denis280's Avatar
yes. I noticed the acceleration pump is weak. gone to change it
Old Nov 7, 2025 | 12:59 PM
denis280's Avatar
after changing the carb with new one. now it runs, and it stall when hot. (choke open run fine, but die when i it the gas pedal
Old Nov 9, 2025 | 10:28 AM
Can you see the Accelerator pump working when looking down the throat of the carb????
A good Strong shot of fuel? OR is it wewak or none?
Old Nov 9, 2025 | 07:31 PM
denis280's Avatar
very strong one. wondering if i should change the old base gasket for new one
Old Nov 11, 2025 | 05:02 PM
Definitely check it for vacuum leaks
Old Nov 12, 2025 | 06:51 AM
denis280's Avatar
I will, thank you RacerHog. will come back with result
Old Nov 12, 2025 | 04:28 PM
Check your timing…
Mason440cuda
Jun 13, 2018 01:56 PM
sswagner3
Sep 18, 2016 05:21 AM
usedknobby
May 29, 2013 01:06 AM
buttton
Apr 1, 2013 10:00 AM
moparsforlife
Sep 2, 2009 04:47 PM
