Starter and alternator
Old Apr 4, 2011 | 04:29 PM
captaintom's Avatar
My '68 RR should be ready for early summer after total restoration. Any thoughts on starter,alternator and mufflers. Headders are 1.78 and engine is 383 ..30 over with little bit of a cam?
Old Apr 5, 2011 | 02:09 PM
John Van's Avatar
Does looks matter? Are you trying to keep it stock? If not,a powermaster mini starter,a Denso alternator.mufflers,I love the flowmaster 44's,but the 40 series might be better for you.
just my .02 worth, john
Old Apr 5, 2011 | 02:15 PM
Depends on what you are planning 100 point resto / Not with headers . SO I would update the regulator to the later electronic version and the corresponding alternator. The smaller mopar performance/ newer style starter may be of benefit with the headers. Some nice Dynomax mufflers or Flowmasters. I had 3 chamber flowmasters on the 67 Coronnet I used to have. The two chamber were too loud on the street, at least for me... If you have any type of aftermarket shifter that uses a cable make sure to use some type of heat wrap on the cable
Old Apr 5, 2011 | 03:47 PM
Silverick's Avatar
As far as mufflers go....
I have Flowmaster Super 40's (2 chamber) on my slammed Chev. pickup and Flowmaster 50's (3 chamber) on my 383 Fury.
They both sound great but, my pickup is loud to the point that I am changing the mufflers, this week!
The Fury just sounds healthy!
Old Apr 5, 2011 | 03:52 PM
captaintom's Avatar
It will be driven on weekends and such. I would like to put it back to stock maybe some day. I will be putting an aluminum radiator and already put in front disc brakes. I have a'96 mustang gt convert. with flowmasters and it is a little bit loud but not unbearable.
Old Apr 6, 2011 | 06:52 PM
scotts74birds's Avatar
I read that the mini-starter from some of the Dakotas works fine on even a stroker BB. Just a tip to save from a Big-Buck aftermarket starter.
Old May 5, 2011 | 04:03 PM
I got this starter from Summit..it was their brand...I still have yet to fire it off but the price was right...the bottom stud hole was too small..I had to drill it out...
Old May 5, 2011 | 04:26 PM
This monstor alternator
My new 120 amp Nippon Denso alternator ...$141.81 to my door...I got it at Spider Marine Electric Supply part number is...A12066...get it on line here...
http://www.spidermarine.com/ this was built for a John Deer tractor
Old Mar 30, 2012 | 08:42 PM
Altosax's Avatar
Good find and convenient location for the output stud, also came with that pulley. Good price not a reman!
Old Mar 31, 2012 | 07:13 AM
Archer's Avatar
CptTom -
If you have headers, then IMHO, a mini/high torque starter is a must. Also make sure there's some kind of heat shielding for both the starter and the wires.
I'm using (and just had rebuild) my stock 60amp alternator and it runs fine and safe for any "older" wiring you might have. Just think it looks cool too. (Sorry Eric, that one just isn't "Chrysler" enough, LOL.)
Probably the Magnaflow or Flowmaster mufflers are fine, but I'm still using old Walker hemi mufflers on a new exhaust system, and they are holding up quite well. (Sounds good too.)
kkritsilas
Jul 2, 2013 07:06 PM
dyera1
May 6, 2013 08:53 PM
daviddea
Dec 30, 2011 08:11 AM
Mopar_Fan
Oct 2, 2011 08:24 PM
sgoffena
Nov 9, 2007 07:55 PM
