Turn sign (flasher) is not working when engine is running...
Old 09-21-2019, 10:57 PM
Jetman's Avatar
Turn indicators (flasher) is not working when engine is running...
Hi guys, I have been struggeling with an issue for a long time a nobody seems to can help me. So im hoping somebody here have the answer :-)
I installed a new Altenator from March performance (P595) and also new LED taillights from Digi-tails and along with this a LOAD flasher as the leds do not pull as much power.
So everything works PERFECT when engine is off, but as soon as the engine is on the blinkers do NOT flash, they light all the time.
Digi-tails told me to try to install a 10 ohm 25 what resistor from grond to the signal wire of both sides - that dont help. then they told me to install a radio capacitor instead - that did not help either.
I did talk to March performance about the alternator and he voltage that it charges with is correct.
I disconnected the AMP gauge like the attached drawing. Any ideas guys?
Old 09-22-2019, 11:20 AM
Sounds like you got the wrong or bad flashing unit.... I would try another brand and the best quality you can find.... Just my 2 cents
FYI, I use LED's lighting in my old 1977 Dodge Pick Up.... But I also had issues, so I just use the incandescent bulbs up front... I'm sure i can fix the problem, I have just never persuade it...
hckrphil
09-22-2019 12:35 AM
dodgem880
04-05-2017 06:47 PM
74Runneer
03-10-2014 06:10 PM
Drakovich
05-19-2011 11:50 AM
dorseyh
09-01-2009 05:09 PM
Quick Reply: Turn sign (flasher) is not working when engine is running...
