1974 Cuda dash speaker cover
Old Dec 11, 2024 | 10:46 AM
sendust's Avatar
Does anyone know if there are screw or bolts holding down the cover? thanks pete
Old Dec 11, 2024 | 03:04 PM
I don’t know for certain but I can’t imagine bolts holding down a speaker cover in a stock application. I only remember chrome screw's.
Old Dec 11, 2024 | 03:31 PM
sendust's Avatar
Im waiting for a tool to get lower screws but it seems when i try to remove the upper ones, they just spin. pete
Old Dec 11, 2024 | 03:48 PM
I pretty sure those had J-Nuts.... And it sounds like they could be broken..... You will have to try to get ahold of the wing with a pair of vise-grips to spin them out....
Old Dec 11, 2024 | 04:51 PM
sendust's Avatar
No room to use vice grips from above,
Old Dec 11, 2024 | 06:49 PM
Got to go in from underneath the dash!!!
Old Dec 12, 2024 | 05:12 AM
Kuvasz101's Avatar
Place a small, bladed screwdriver under the corner of the speaker and pry up while removing the screws.
Old Dec 12, 2024 | 11:35 AM
sendust's Avatar
Will try that tomorrow when my ratchet arrives. thanks
Old Dec 15, 2024 | 03:39 PM
sendust's Avatar
I found the speaker cover was glued down using silicone, the screws were held by the material, after prying off i found the speaker appears to have been installed before a new dash pad was installed. unfortunately the speaker mounting screws or bolts are not visible from above or below. I will cut out the center of the speaker and install the new one from above. Any recommendations of speaker to use, I have a kenwood radio and a phoenix amp . I will tap into the negative side of the front left and positive of the front right to feed new speaker, also add a l pad to control volume. pete
Old Dec 18, 2024 | 09:22 AM
Lots of good name brand speakers out there..... I think it just come down to what you find that will fit in the hole without having to cut the dash up....
if you dont find anything... Check out .... Classic Car Stereos for a replacement speaker.....I think they have direct fit stuff....
Old Dec 19, 2024 | 06:26 PM
sendust's Avatar
Thanks pete
northerncuda1970
Oct 28, 2020 09:08 AM
TVLynn
Jun 7, 2016 06:59 PM
Cracocuda
May 1, 2014 04:54 PM
mek2280
May 12, 2012 07:52 AM
72sat
Oct 23, 2011 05:53 AM
