72 plymouth scamp 225 slant 6 for 2000
Old Mar 3, 2013 | 03:32 PM
andrew77760's Avatar
Talking 72 plymouth scamp 225 slant 6 for 2000
72 scamp bought it for 3000 big mistake, headers double barrel card, headers, flowmaster exuahst, rough interior, no rust, few dents exterior needs rebuilt slant 6 but runs and drives now
Old Mar 3, 2013 | 06:45 PM
bernardotom's Avatar
Its a classic! Not makin them anymore! Enjoy it....you can always sell it later.
Old Mar 4, 2013 | 05:25 AM
What do you think it would cost to rebuild. The engine?
Old Mar 4, 2013 | 08:55 AM
If you do it all, whatever a rebuild kit costs, probably around $500. The more an engine shop does for you, the more the price will be.
Old Mar 4, 2013 | 11:51 AM
I got a quote here in cali for 4gs that's if I do no work myself, I've never rebuilt any kind of car engine only a dirtbike engine, do you think having no experience I can still do it?
Old Mar 4, 2013 | 11:54 AM
As of right now I have tons of blowby, white smoke accompanied with oil comming out of the exauhst, I have the compression test results ill post when I get home so you can let me know what you think
Old Mar 4, 2013 | 02:04 PM
pro-tech's Avatar
I think you could do it. If you get into trouble we are all here to help you. You will need a good machine shop to help you with the machine work you will need. all totaled you will have somewhere about 1500 to 2000 inthe overhaul if you do the assembly of the engine
Old Mar 5, 2013 | 01:58 PM
Is there any kind of cheap temporary fix to the problems I'm having??
Old Mar 5, 2013 | 02:24 PM
pro-tech's Avatar
Did the car sit for a long time? You could try changing the oil with high zinc added and adding marvel mystery oil to free up the rings. Then I would change the oil again in 1000-1500 and do the same thing use a 10w40 0r 20w50 as the MMO will thin it out a bit but it works great to free up rings and lifters and also cleans the internal engine parts.
Old Apr 4, 2013 | 11:39 PM
Reduced price to 1000
Old Apr 5, 2013 | 11:58 AM
Slant 6 is very easy to remove I would check with Waynes engine in Riverside area
http://www.waynesengines.com/
They could build you a long block
A complete rebuilt assembled long block will probably cost $1500
78Custom
Aug 31, 2013 12:46 PM
Sign Guy
Apr 22, 2013 10:01 AM
MonroePRacing
Jan 4, 2012 07:00 PM
hatboy2002
Jun 18, 2008 10:05 AM
1980b100van
May 2, 2008 09:53 AM
