best way to lower a dart
Old May 6, 2009 | 02:32 PM
reilly's Avatar
Junior Member
whats the best way to lower a 1974 dodge dart may be 1 inch in the front give or take
Old May 6, 2009 | 02:47 PM
Crazy4Carz.Com's Avatar
Your Dart has a torsion bar front end. It is as easy as turning a screw. Find in the middle of your lower control arm a 3/4 inch bolt turn it counterclockwise and the front end comes right down. That easy. For the rear you can either replace the springs or use blocks, or change the rear shackles to a shorter set. Very easy as well.
Old May 6, 2009 | 02:58 PM
reilly's Avatar
Junior Member
well that easy thanks ,bad news I just had my alignment done should i have it redone when I find the spot I like its just I had new tires put on and they killed the bank.
Old May 6, 2009 | 05:19 PM
johnthegoalie's Avatar
thinkin with me dipstick
before you do it - spray the bolt and the block it threads in with some wd40 and let it site for a few hours. make sure when you are turning it the bolts they are relatively east to move - the first time i adjusted mine, after being in the same spot for 35 years, the bolt seized, snapped and the car dropped almost taking my arm off...
Old May 6, 2009 | 06:38 PM
scotts74birds's Avatar
Quick tip.....For this kind of stuff I found something called "Aero-Kroil",they use it at my plant. You can get it online. Honest testimonial here. Stuff is the bomb for rusty things. Puts WD to shame.
Old May 7, 2009 | 10:32 AM
reilly's Avatar
Junior Member
see that what iam talking about good to know bolt mite snap and car mite fall its allways the little things
Old May 12, 2009 | 10:17 AM
Originally Posted by hypermite
Actually, ( and this is Just my opinion ) the "best" way to lower a Dart is to stuff a big block under the hood !
YES! I changed my mind, I like that best too!
Old May 12, 2009 | 12:24 PM
Polaradude's Avatar
X3 on that one. But the torsion bars work...lol
Old Aug 4, 2009 | 07:06 PM
Mr.Duster's Avatar
lol please tell me ur not going to lower it like a low rider i just think that looks stupid on the old mopars
Old Aug 5, 2009 | 04:23 PM
agreed
Rumblefish318
Aug 29, 2012 10:19 AM
69POLARA383
May 18, 2012 10:49 PM
tahoeskier
Jun 18, 2011 06:59 PM
Demonized
Jun 17, 2010 06:21 PM
ngc414
Aug 31, 2009 01:27 PM
