gas problems
Old Jun 2, 2010 | 07:28 AM
dartonboy's Avatar
Junior Member
gas problems
I have just gotten a 1973 Duster, and I have only been it driving around the yard for now. it has a 225 slant 6 in it and it has always started with the turn of a key, that is before I dumped a can of gasoline in the tank, now it just turns over and will not even fire. it is getting gas to the carb, now for my question.
since I have never added gas to it before, it has been running on the old gas in the tank which I don't even know how old it was, should I have added a lead additive or something else to the tank also? why wont my car run on the new gasoline I dumped in the tank? its the same gas i put in my mower and it runs just fine.
any ideals or help will be greatly appreciated.
Old Jun 2, 2010 | 07:36 AM
Archer's Avatar
darton -
Welcome aboard
Assuming you actually added gas (as in "from a gas pump", not sure about the "can" thing), only only way I can think of that happening is that you have a bizarre coincidence. Meaning - something "else" happened when you were refueling. Sure you still have park?
Today's gas may be crap by past standards, but there's really no reason for the car not to fire.
Old Jun 2, 2010 | 08:14 AM
Flammopar's Avatar
Are you positive it is getting gas to the carb and not flooding it? If so the only other option would be spark... Adding new gasto is could have disrupted the crud in the tank from sitting and clogged the sock filter inside it. Just my thoughts, Im not a expert.
Old Jun 2, 2010 | 08:42 AM
sweeperking's Avatar
Unless you know for sure you have the harden valves yes you need to add the lead additive or like product. As far as your no start issue, start with the basics. You say there is fuel at the carb I assume you checked that the accelerator pump is actually pumping fuel. The next step would be to check for spark. Either no spark or no fuel once you figure that out it would be easier to go from there in troubleshooting.
Old Jun 2, 2010 | 04:45 PM
1966sportfury's Avatar
A.K.A Bob Dodge
maybe the tank is rusted and when you added gas you stirred up a bunch of gunk so when you went to start it that blocked the fuel line... will it start with a lil bit of gas poured dwn thw carb?
Old Jun 2, 2010 | 07:19 PM
dartonboy's Avatar
Junior Member
I will try that, also check for spark if that does not work.
I appreciate the help guys, I will let you know my results
Old Jun 2, 2010 | 07:26 PM
theomahamoparguy's Avatar
also remember that the new gasoline has alchohol. sometime this has a negative effect on old rubber. especially if it is on the verge of coming apart. tends to clog needle and seats. {think fuel injection hose as a good replacement, alchohol resistant}...........just one idea, could be crap in the tank too...
xvodysseusvx
Jun 25, 2018 04:38 PM
NeverEnoughAuto
Sep 12, 2014 06:17 AM
Foedoe
Mar 8, 2011 07:47 AM
bigsho
Jul 8, 2009 06:40 PM
73_Mopar_Muscle
Jan 30, 2008 10:57 AM
