Manual Disc to Power Disc
Old Nov 29, 2008 | 08:58 PM
Welcome to the forum
not sure about power brakes, but i am sure someone on here can help you
Old Nov 30, 2008 | 03:05 AM
Welcome to the forum.
You will need a power booster, master cylinder and posibly a different brake pedal set up. The lines and everything ense should be the same. Plus a vacuum port from the intake.
Old Nov 30, 2008 | 09:14 AM
challenger's Avatar
i think you will also need a different pro valve and the brake pedal you might just have to change out the rod ..... is that correct 78 ?
Old Dec 1, 2008 | 02:17 AM
proportioning valve might have to get changed, i'd do it though just to be on the safe side.
HorizonChaser
May 17, 2015 02:41 PM
1968GTX
Jan 25, 2014 10:40 AM
HonkyCat
Nov 3, 2012 10:09 AM
thedusterridesagain
Sep 20, 2012 07:57 PM
Jwhis
Mar 19, 2012 04:09 PM
