New master cylinder leaking from lid yikes
Old Dec 6, 2010 | 05:33 PM
mytracy's Avatar
Hey guys as my last post said i redid my brakes but today ive learned to not trust my fuel gauge and it ran out when it said i had a quarter tank left this pertains to what may have happened. so got gas in it again, drove it to my radiator shop where i open the hood and its dripping ughhh. now from me losing power brakes due to it dieing from no fuel can that pressure being applied to stop the car with no vacum to the power brakes push some of the brake fluid out of the lid? thats what happened i think to the other one that was for a all wheel drum car to much pressure it pushed brake fluid out of the lid so what do you guys think?
thanks in advance
Old Dec 6, 2010 | 05:41 PM
I'm having a problem following all this, but running a vehicle out of fuel should NOT cause various leaks in the systems of the vehicle.
So I dooonnooooo, maybe you simply overfilled the master and if finally heated up enough, and expanded enough, to blow some fluid out.
Old Dec 6, 2010 | 10:36 PM
mytracy's Avatar
sorry for not being clear, like when the engine shuts off from no fuel i lost my power everything including vacuum to my brakes causing me to have manual brakes to stop it with lots of force thus maybe causing it to leak like that?
Old Dec 7, 2010 | 03:26 AM
Crazy4Carz.Com's Avatar
I think I understand what you are saying. From the additional pedal pressure you had to apply because of the engine not running, you think this caused the leak? Nope, line pressure is the same regardless of your pedal pressure or the power booster pressure.
Old Dec 7, 2010 | 04:25 AM
It is leaking out of the lid? Is the gasket on the lid cut or folded over maybe?
Old Dec 7, 2010 | 08:11 AM
mytracy's Avatar
thanks guys for the help
i checked the lid and it looks fine, im puzzled why it would do that? maybe try a higher DOT rated fluid?
Dave E
Dec 20, 2013 02:00 PM
MojoHaiku
Aug 22, 2012 10:34 AM
jar84203
Oct 12, 2010 05:07 PM
Imperial1973
Sep 5, 2009 10:17 AM
buttslapper
Oct 1, 2007 06:32 AM
