temp gauge help ????
Old May 20, 2012 | 05:52 PM
67hemidart's Avatar
looking to install a after market temp gauge and there is no place to install it on my intake. I was wondering if any one had a thought about putting a brass tee on the intake where the heater core line connects just not sure if anyone had a different idea ? there is a hole in the intake for a small probe but the one that came with the gauge is approx 3/8" ips the intake is liken 1/4" thanks guy's
Old May 20, 2012 | 06:54 PM
Stock intake only has the 1/4" pipe thread opening for the stock temp sending unit. You could find a spot near that one and drill a hole and tap it for 3/8" pipe thread opening.
Old May 21, 2012 | 11:19 AM
Depending on who makes the gauge, you can get the special adapter that the gauge tube fits into (these are proprietary pieces) down to sometimes 3/8" US pipe thread, which is some help
Also, GM had some (maybe aftermarket) thermostat housings which had an extra fitting boss int he top of the housing. I do not know if it's tall enough to clear the probe or not
Be careful drilling/ retapping a manifold. They can be very thin, and provide little "meat" for threads
This has been a problem that has plagued us Mopar drivers all our lives. Even Edelbrock just could not bring themselves to provide a "standard" boss for the large water temp fitting.
There was a member over at A Bodies Only who claimed to be (or was) an engineer at Autometer. He claims their electric temp gauges are as accurate as any mechanical gauge. Years ago, I got burned BAD by an electric SW gauge.
Old May 21, 2012 | 12:38 PM
Archer's Avatar
440 -
Isn't/wasn't there a wire sender that fits into the radiator hose (under the clamp)?
Old May 21, 2012 | 01:39 PM
The Eddy small block Performer has several 3/8" holes to choose from.
Old May 21, 2012 | 03:16 PM
67hemidart's Avatar
intake
holly crap Eric that intake looks like Swiss cheese !!!!!!! mite need a few plugs when in use !!!!
Old May 21, 2012 | 03:25 PM
67hemidart's Avatar
Thanks Guy's I Thought I was S. out of luck . will try to come up with some thing
I truly do not trust the factory equipment (1967 era).
Old May 21, 2012 | 05:22 PM
Ya, but "back in the day" that wasn't so, AND the smaller temp gauge mounts were not commonly available in 3/8, either. Most of the traditional mechanical gauges, even SW, only came with 1/2" mounts
And yes, there was a radiator hose mount. This is a piece that is/ was sold in order to tap in some engine heaters, but it looks kinda hokey
Old May 21, 2012 | 05:29 PM
67hemidart's Avatar
I was going to try to hide it at the back of the motor near the heater core so it is less noticeable but just dont think it will get the volume needed ? and if there was a slow leak could go unnoticed by others !!!!!
mopardude73
Apr 26, 2014 05:03 PM
Norskinder
Oct 15, 2011 08:09 AM
sendust
Aug 24, 2011 12:48 PM
cletis
Cuda Specific Discussion
Jun 1, 2011 04:29 PM
belve2
Mar 9, 2010 07:20 AM
