Why is the camber so much?
Old Nov 22, 2010 | 08:47 AM
mytracy's Avatar
Excessive front tire camber? When i bought the dart i saw it like this i checked the underneath and all looks ok, except maybe the upper ball joint? Is this adjustable? Both front tires are like this.
Old Nov 22, 2010 | 02:00 PM
is that the original front end? after 38 years the, the front end begins to wear out. mine looked like that too. it needed all new bushings, ball joints, etc.
it is not the worst job, so dont get nervous
check the upper and lower control arms bushings, along with all of the other bushings, joints, etc.
Old Nov 22, 2010 | 02:55 PM
Silverick's Avatar
67 GTX is correct.
But, if the previous owner cranked the torsion bars down to lower the car and then never adjusted the camber to compensate.... this is how it will look.
It's something to think about.
Does the car have a forward rake? (Dropped in the front look?)
If this is the issue, the torsion bar adjusting bolts are in the middle of the lower control arm. Measure the existing height and crank the bolts in the direction that raises the car. Make sure and count the turns that you crank the bolts so that you get it even and make sure that both front tires are the same diameter and are aired up evenly or you'll end up crooked.
It's real easy and it may get you straightened out for the time being.
I've done this and then took the car to the alignment shop to square it all up.
By the way: I think I can see the adjusting bolt in your last picture of the lower arm and it looks like it's cranked out pretty far.
Old Nov 23, 2010 | 10:17 AM
mytracy's Avatar
Thanks guys for the help, it does have a very slight foward rake to it. i would take more pics of the front end but its down pooring rain and i have yet to get rid of my other car to put it under a cover. I have my new set of four tires coming in the mail, so i might take it to my les schwab and get the tires mounted and get the alignment and ride height fixed, it does not pull bad even with the excessive camber slight left it pulls.
Old Nov 23, 2010 | 11:07 AM
Silverick's Avatar
It's raining here too. Usually the guys at Les Schwab are pretty sharp. Let them check it out and I am sure that they can straighten it up for you for the time being. Good luck!
Old Nov 23, 2010 | 11:16 AM
mytracy's Avatar
Thanks man!
Old Nov 23, 2010 | 01:40 PM
be careful though
if the bushings are worn out, they won't hold a re-adjustment
Old Nov 23, 2010 | 07:05 PM
Silverick's Avatar
Originally Posted by 67 GTX
be careful though
X2
Old Nov 24, 2010 | 08:04 AM
mytracy's Avatar
Good to know, when i was up under the car. all the bushings and balljoints looked ok to good not bad like my other classic car when i bought that one but then again it was also 10 years older lol
Old Nov 24, 2010 | 03:33 PM
did you also check the allignments bushings?
Old Nov 24, 2010 | 08:00 PM
mytracy's Avatar
I have yet to check that
Old Nov 25, 2010 | 10:51 AM
those are probably worn out
72Charlotte
Jul 21, 2014 03:25 AM
fluffoffal
Oct 9, 2012 03:53 AM
mfleck_us
Sep 11, 2010 06:27 PM
Buffalojoe426
May 14, 2010 03:42 AM
recondotexas
Feb 6, 2010 10:39 AM
