340 block, "J" heads, cast crank and 727 trans
Old Oct 14, 2012 | 09:37 AM
dpmalibu's Avatar
Block needs to be honed due to surface rust in cylinders. It does have new freeze out plugs and cam bearings. bearing have some surface rust from sitting. casting #'s are 2780930-340-5 and date code is 1/12/73 Asking $425
Stock cast crankshaft from the 340. In very good shape. its wrapped in plastic so there is no rust on journals. $125
"J" casting cylinder heads (1970-72) need to be redone. Valve size is 1.88/1.60 .Heads are clean casting #'s are 3418915-F and 3418915-C $200
727 trans came out of same car. has 86k miles on it. Needs to be rebuilt $125
original 340 air cleaner base (don't have top) $30
located in Hatboro,Pa
Old Oct 21, 2012 | 02:31 PM
dpmalibu's Avatar
new prices:
block $300
crank shaft $100
heads $100pr.
727 trans $75
air cleaner base $20
Old Oct 21, 2012 | 03:23 PM
Mr.Duster's Avatar
does the block have any cracks or been tested it looks pretty beat(any pictures of the cylinder walls). What year is it im looking for 70 block
Old Oct 25, 2012 | 07:48 PM
MrOldart2U's Avatar
block looks like a rusted mess.... sure needs a hard cleaning....
Old Oct 27, 2012 | 01:12 PM
dpmalibu's Avatar
it does have surface rust from sitting. If you look closely you can see it has new freeze out plugs and cam bearings. It was bought from a machine shop by the previous owner. unfortunately it was not oiled down when stored. All that would have to be done is take it to a machine shop and put it in the tumbler and the block would look like new. Also a good honing would help too. As as far as I know the block is good. I don't think somebody would have started putting money into it if it wasn't. I could get it cleaned up and checked for cracks but the price would go up considerably. it is a 73' block.
Old Dec 8, 2012 | 07:37 PM
Clyne_duster72's Avatar
You still have crank for sale?
Old Jan 21, 2013 | 11:12 AM
dpmalibu's Avatar
Everything is sold
74Runneer
Mar 11, 2013 08:03 PM
HonkyCat
Nov 26, 2012 07:54 AM
pipdog69
Mar 13, 2012 11:01 PM
Minnesota Guy
Oct 21, 2010 10:41 AM
atowncris
Nov 19, 2009 12:48 PM
