Drilled Through Cylinder Head
Old Mar 22, 2022 | 04:58 PM
Andy777's Avatar
Need some help. I was working on 77 360. The last exhaust stud near #8 piston was broken of so I was drilling it out to use an easy out and I drilled through the head. After that the easy out tip broke off and as I was trying to get that out it pushed through and disappeared. I pulled the head off and can't find it anywhere. Anyone know if this will be an issue?
Old Mar 24, 2022 | 10:21 AM
More than likely it fell down into the water passage and went down into the coolant passage in the engine block... You mite be able to use a magnet and fish it out if it went straight down to the bottom of the passage.
Old Mar 24, 2022 | 06:42 PM
I can’t believe it would be a problem…
Old Mar 24, 2022 | 06:59 PM
Andy777's Avatar
Thanks guys. I'm gonna bolt it back together and run it.
Old Mar 25, 2022 | 06:54 AM
dodgem880
Oct 12, 2019 10:41 AM
raycan2
Oct 1, 2014 03:13 PM
Shrug
17
Feb 26, 2013 05:50 AM
tagster
Sep 9, 2010 01:04 PM
old tired rebel
Apr 7, 2010 07:08 AM
