Return fuel line
Old Feb 8, 2015 | 08:59 PM
smithwickian's Avatar
Return fuel line
HELP!
I have a 360cu Dodge engine in my Dart with an Edelbrock 750 carb and was wondering how important it is to have a fuel/vapor return line to the tank? I'm getting lots of bubbles in the pump and filter and the engine bogs down a little upon rapid acceleration.
Old Feb 9, 2015 | 08:52 AM
Did not know they had fuel return in 1970 Dodge Darts????
Anyway... I would guess you have a Loose or leaking hose somewhere down stream of the fuel pump to cause those bubbles....
Just my 2 cents
Old Feb 9, 2015 | 01:02 PM
The only reason you might need a return line is if you have converted to an electric fuel pump
Old Feb 10, 2015 | 07:33 AM
Gorts 5th's Avatar
Smile
If there are bubles in the fuel you have a leak...a seald fuel system is important too keep vapor locking , I had the same issue last summer found a vent line with a crack in it.
my return line works off of the fuel filter some run the return off the fuel pump
But as racerhog says u may not have a return on ur duster
BTYM
Mar 10, 2014 06:09 AM
1968newport
16
Sep 20, 2013 03:52 PM
cudagecko
Apr 19, 2013 02:54 PM
Coating Methods
Sep 26, 2011 05:17 PM
dboland
Sep 2, 2008 03:59 PM
