1962 Plymouth Savoy
Old Oct 19, 2015 | 04:07 PM
project62's Avatar
1962 Plymouth Savoy
First father and son project car. Any advice is welcome. Thanks
https://moparforums.com/forums/attac...1&d=1445295412
Attached Thumbnails 1962 Plymouth Savoy-2015-10-18-18.09.52.jpg   1962 Plymouth Savoy-2015-10-18-18.11.33-copy.jpg   1962 Plymouth Savoy-2015-10-18-18.10.41-copy.jpg   1962 Plymouth Savoy-2015-10-18-18.11.15-copy.jpg   1962 Plymouth Savoy-2015-10-18-18.09.19-copy.jpg
1962 Plymouth Savoy-2015-10-18-18.08.45-copy.jpg   1962 Plymouth Savoy-2015-10-18-18.09.38.jpg
Old Oct 19, 2015 | 05:44 PM
Magoo's Avatar
Thumbs up NEAT PROJECT
-- Welcome -- Cool project - not many of these around. -- I've had a few 60s Mopars - see my albums. - I'm not a engine builder or a body man, (just a Mopar guy) but possibly I can help here and there. -- Good luck with the project.
Old Oct 19, 2015 | 06:01 PM
Looks cool,
I've got a friend with a 62, it's a E/SA car and has run a legal 10.60. What are your plans for the car?
Old Oct 21, 2015 | 12:47 PM
project62's Avatar
fix all the rust, freshen up the 383 and maybe street/strip. and if the body work is good enough take it to some car shows. even if body work isn't that great, may still take it to car shows. white hides alot of flaws. i want to sell the 383 and put in a 440, but one of my sons wants to keep the motor. my cousin told me it's a numbers matching 383 for a 68 roadrunner.
Old Oct 21, 2015 | 04:57 PM
You could stay with the 383 but add a stoker kit. I like father son projects, how old are your boys?
Old Oct 22, 2015 | 12:33 PM
project62's Avatar
oldest is 19 in college for classic car restoration at Ohio Technical college in cleveland 2nd oldest is 18 senior in high school and thinking of going to OTC for high performance.
Old Oct 22, 2015 | 01:18 PM
Talk about a perfect fit, your Plymouth should be rock'n in no time.
You can call it homework! lol
Old Oct 23, 2015 | 08:06 PM
If the Collage is close enough..... Might get some good labor done at a great price..... Just a thought......
Now with that said....
Blow it apart.....
media Blast....
Replace needed panels...
Refit all Body panels...
Get the good stuff... Primer.... Build Primer.... Block sand it.... Paint it inside and out.....
http://www.tcpglobal.com/Automotive-Paint/
O.H suspion....
Wiring and intiorer and engine and trans...
Go whoop Azz on some brand-X
Great Project
Old Oct 28, 2015 | 10:54 AM
project62's Avatar
Blow it apart.....
media Blast....
O.H suspion....
Great Project
What type of material do you use when you media blast a car? I was told not too media blast because it will warp the panels. Also if you could help me out with something, the hood is completely unsalvagable and same with the trunk lid. Where can i find replacements? Having trouble finding them.
Old Oct 28, 2015 | 11:14 AM
Magoo's Avatar
Smile Hood for a 62 Plym
-- the hood is completely unsalvagable and same with the trunk lid. Where can i find replacements? Having trouble finding them.
-- Check here for a hood -- www.sledcityevents.com -- then click on Fiberglass. -- A bit pricey, depending on the alternative. -- ALSO -- Here's a phone number in N.J. -- 732-268-2220. -- This is a 4 door parts car - not sure what parts are available. - Perhaps you've already checked this one.
Old Oct 28, 2015 | 06:16 PM
Also Post it here in the parts wanted section....
Hemmings motor news....
http://www.dvap.com/
E-Bay
You Just never know when one will pop up....
Old Oct 28, 2015 | 06:34 PM
Magoo's Avatar
Smile Hood & Trunk Lid
If timing isn't a problem, then wait and go to "Spring Carlisle" in Carlisle, Pa. 4/20 thru 4/24/2016. -- And/Or -- "Chryslers At Carlisle" 7/15 thru 7/17/2016.. -- The July event is probably your best chance to find something. -- There's also a big events in Charlotte N.C. (Charlotte Auto Fair) 4/7 thru 4/10/2016, and "The Mopar Nationals" in Columbus 8/12 thru 8/14/16 -- You should find something at one of these events. -- Sound like you guys are in Ohio, if so then all of these places are reasonably within your reach.
Old Oct 28, 2015 | 06:41 PM
Might also Check a few of these out.....
http://www.cpwclub.com/springevents/content-2/
http://www.mooresautosalvage.com/about.asp
Old Oct 31, 2015 | 11:40 AM
project62's Avatar
https://moparforums.com/forums/attac...1&d=1446316793
think we have a problem
Old Oct 31, 2015 | 12:43 PM
Time for a 440 block.
Old Oct 31, 2015 | 01:40 PM
Magoo's Avatar
Unhappy Not Good
-- Ouch !! --
Old Nov 1, 2015 | 11:02 AM
Ouch..... Might be time to look at that upgrade..... However 383 blocks are not hard to come by.....
Old Nov 1, 2015 | 05:05 PM
project62's Avatar
Originally Posted by Magoo
-- Ouch !! --
After some extensive research. That big hole is suppose to be there. Just when you look at from that view it looks busted. After we took timing chain off, it's actually part of the casting. Must be channel for oil to lubricate timing chain.
Old Nov 1, 2015 | 05:12 PM
Magoo's Avatar
Smile
-- -- Good news - That should save some bucks.
Old Nov 1, 2015 | 07:58 PM
I thought it was time for a 440!
Old Nov 2, 2015 | 03:33 AM
project62's Avatar
Going on a road trip with the boys on the 14th of this month down to Columbus Ohio. There's a 6th Annual Ohio Mopar Expo Swap Meet and Car Corral for Chrysler, Plymouth, Dodge and related vehicles, Ohio Expo Center & State Fair, Rhodes Building, 717 E. 17th Ave., 43211, 9am-4pm, indoor swap and corral space available.
try our luck there.
Old Nov 2, 2015 | 12:24 PM
project62's Avatar
so this 383 i have was built 3 9 68 the block casting is 2468130 which tells me its a 383 b motor and was built at 1pm. what does the 10 stand for at the end of the casting number?
My cousin has informed me that its a numbers matching engine for a '68 roadrunner.
409Whit
Sep 17, 2013 06:28 AM
tonypowell
Jul 8, 2011 10:15 PM
tonypowell
Jul 6, 2011 03:57 PM
DMV
Mar 10, 2011 10:54 PM
DMV
Mar 9, 2011 06:58 AM
