67 Coronet R/T Prostreet/Ratrod
Old Apr 14, 2013 | 08:37 AM
  #31
Any progress???? I have been waiting to hear how it is running....... I'm impatient about things like this????
Old Apr 14, 2013 | 10:17 AM
  #32
PURPLE HORONET's Avatar
Was working on a couple of other things for a bit, but tomorrow I am ordering the rest of my stuff to stick it in and fire it up... Should have a video of it running with in 2 weeks orr less..
Ordering monday
Headers
copper header gaskets
mini starter
one wire alternator
plug wires
coil
holley electric fuel pump
Mopar fan and shroud
fuel line kit from cell to engine
I am going to start the car and break the cam in on a single fout carb. Then when I get all the bugs worked out like my complete rewire job, exhaust, and the drive ability im sticking the tunnel ram on.
Old Apr 17, 2013 | 11:33 PM
  #33
Got some parts in today,, the rest should be in tomorrow so I can put the engine in..
Hooker competetion headers 16 gauge 1 7/8 tube,, Mini starter
Attached Thumbnails 67 Coronet R/T Prostreet/Ratrod-v3.jpg   67 Coronet R/T Prostreet/Ratrod-v2.jpg   67 Coronet R/T Prostreet/Ratrod-v6.jpg   67 Coronet R/T Prostreet/Ratrod-v5.jpg
Old Apr 17, 2013 | 11:44 PM
  #34
Tuff stuff one wire 100amp powder coated alt,, Holley pump and complete line kit from fuel cell to engine bay,, Also my favorite street fan with the best cooling and does not sound like a leaf blower going down the road like all non clutch fans. The Mopar performance Viscous fan.. I remember when I was younger, I always took the clutch fan off and stuck a flex fan on.. Dont know why, maybe I thought it was cool.. But the sound they make really sucks.. Just like those old s-10 blazers you here nothing but fan when they are going down the road.. LOL
Attached Thumbnails 67 Coronet R/T Prostreet/Ratrod-v7.jpg   67 Coronet R/T Prostreet/Ratrod-v1.jpg   67 Coronet R/T Prostreet/Ratrod-v4.jpg
Old Apr 20, 2013 | 06:52 AM
  #35
Where did you get the alt??? I need one for a spare... Thanks M
Old Apr 20, 2013 | 07:15 AM
  #36
Gorts 5th's Avatar
Smile
Thats what i do swap the clutch for a really large Noisy flex with the ac on and sitting in traffic she makes a difference over the one thats on the motor..
how will that perform over my oem clutch? i would rather not have "the roar" of the flex but i don't want to suffer cfm at stop and go traffic speeds... what's the part number? DO4B1? summer is warming up here quick it was 95 yesterday and humid.
Old Apr 20, 2013 | 12:00 PM
  #37
Block decked, heads surfaced ? Make sure to check the intake fit !!!!
Old Apr 21, 2013 | 12:07 AM
  #38
Summit
http://www.summitracing.com/parts/tf...iew/make/dodge
They also have a double pulley or satain finish and different amps
Not sure if we are on the same page, I do not like flex fans.. Summit for the fan..
http://www.summitracing.com/parts/dcc-4120758
Most late 1960s and early 1970s factory-built musclecars were equipped with viscous fans for cooling purposes. Engineers determined through dyno testing that you could gain up to 15 extra horsepower with typical high-performance V8s
Old Apr 21, 2013 | 12:24 AM
  #39
Been busy have not had a chance to stick the engine in.. Big b-day party in my shop/ man cave friday night. Had to get all my stuff moved around.. Got to mess with it a bit tonight.. Stuck the motor mounts on and stuck the converter in and water plugs on the block.. I really think this week it will get fired up..
Parts
New B&M Holeshot Converter 2800-3000, B&M Flexplate SFI appr. ARP 7/16 bolts.. And new motor mounts and trans mount. I had to buy a new converter I finally found out what was in it.. It was a GER made in PA. they went out of biz years back, and from what I reserched they were a pile of junk..
Attached Thumbnails 67 Coronet R/T Prostreet/Ratrod-v8.jpg   67 Coronet R/T Prostreet/Ratrod-v9.jpg
Old Apr 21, 2013 | 12:49 AM
  #40
Those are not fail safe mounts. Make sure you have some type of torque strap
Old Apr 21, 2013 | 08:56 AM
  #41
You are correct, If I was goona drag race on the track I would not use these, but for the street it will cut down on vibration.. Going to stick a chain on the left side with just a hair of slack.
Old Apr 23, 2013 | 10:01 PM
  #42
Got the engine set in the car to night,, Not to fun.. First mistake buying 1 7/8 headers.. I only needed 1 3/4 but the 1 3/4 headers were 18 gauge thickness and I wanted the 16 gauge.. They are barley touching the torsion bar in 2 spots on the drivers side and one spot on the pass side.. It seems like if the engine was lifted 1 inch it would be perfect.. I guess tomorrow night will be rose bud on the torch and hammer time.. Atleast its on the bottom were nobody can see the handy work..
Attached Thumbnails 67 Coronet R/T Prostreet/Ratrod-v10.jpg
Old Apr 24, 2013 | 11:25 AM
  #43
RustBeltRodder's Avatar
For anyone else out there considering headers for their RB 68-70 B-Body, I bought cheapy flowtech headers straight out of summit's catalogue and only had to clearance for the stock starter. Non-power steer, Non-power brakes, and column shift auto. Hope someone else finds this useful
Old Apr 24, 2013 | 03:40 PM
  #44
The only down fall is a shady flange and they are beer can thin..
Old May 3, 2013 | 10:35 PM
  #45
you don't happen to be on bmxmuseum.com too, are ya?
Old May 6, 2013 | 09:49 AM
  #46
Not me..
Old May 6, 2013 | 09:56 AM
  #47
Started on the fuel system.. cleaned the fuel cell and got it mounted back in the trunk.. Ran new fuel line and mounted the pump, and mounted the fuel filter under the hood. I stuck it under the hood because thats were I am going to come off of for my carb supply. I went with the holley red pump because a regulator is not needed. It will supply enough fuel for my build.
Attached Thumbnails 67 Coronet R/T Prostreet/Ratrod-z6.jpg   67 Coronet R/T Prostreet/Ratrod-z4.jpg   67 Coronet R/T Prostreet/Ratrod-z8.jpg
Old May 6, 2013 | 10:05 AM
  #48
Got a few more things bolted on the engine, Gonna break the engine in on a single carb before I add the tunnel ram.. The last thing I want to do is to be screwing with carbs tring to start and break-in a new engine. Runnig a hyd. cam not roller..
Had my tunnel ram ceramic coated and got it back last week. Also I got a 2 quart bigger trans pan.
Attached Thumbnails 67 Coronet R/T Prostreet/Ratrod-z7.jpg   67 Coronet R/T Prostreet/Ratrod-z3.jpg   67 Coronet R/T Prostreet/Ratrod-z2.jpg
Old May 6, 2013 | 10:10 AM
  #49
Next week gonna have a big surprise for everybody on this prostreet ratrod project. Your either gonna hate it or love it.. Man I cant wait, its as good as starting a new engine for the first time.. And that is not the surprise..
Old May 6, 2013 | 12:39 PM
  #50
Buffalojoe426's Avatar
Oh boy! I can't wait! Looks like its coming along nice.
Old May 6, 2013 | 09:21 PM
  #51
Few more things added tonight, finished the fuel system added the one wire alt. and power steering pump, mopar fan, new trans lines and installed the radiator. I also installed a big trans cooler. I run a big cooler so I do not need to run the fluid threw the rad.
Attached Thumbnails 67 Coronet R/T Prostreet/Ratrod-z10.jpg   67 Coronet R/T Prostreet/Ratrod-z11.jpg   67 Coronet R/T Prostreet/Ratrod-z9.jpg
Old May 11, 2013 | 04:16 AM
  #52
Its looking very nice!!!!!!! You are getting there for sure!!!!!!!
Old May 12, 2013 | 08:00 PM
  #53
One part at a time, The only thing left before start up is wiring.. I riped all that crusty spliced brital wire out.. LOL no copper left anywere, thats the way I like to do it. Gonna get the wiring done this week. Stay tunned for the surprise should be done with it tuesday..
Attached Thumbnails 67 Coronet R/T Prostreet/Ratrod-z12.jpg
Old May 14, 2013 | 01:34 PM
  #54
I had my car lettered up like a old drag car today,, I thought being I was going with that old shool look it would be cool. All hand painted
Attached Thumbnails 67 Coronet R/T Prostreet/Ratrod-z18.jpg   67 Coronet R/T Prostreet/Ratrod-z17.jpg   67 Coronet R/T Prostreet/Ratrod-z20.jpg   67 Coronet R/T Prostreet/Ratrod-z21.jpg   67 Coronet R/T Prostreet/Ratrod-z19.jpg
Old May 14, 2013 | 01:35 PM
  #55
Can anybody see the last to post I made with the pics.. I just see a red X
Old May 14, 2013 | 03:05 PM
  #56
I see the same.
See Attachment Issue.
Old May 14, 2013 | 08:50 PM
  #57
I HAD THE GUY PAINT IT LIKE IT WAS ON THEIR FOR 30 YEARS
TRY THIS
Old May 14, 2013 | 08:55 PM
  #58
YUP
Old May 14, 2013 | 09:01 PM
  #59
B4 PICS
Old May 15, 2013 | 03:06 PM
  #60
I like them!!!!!!!! No I love them.... They belong on this ride!!!!!!!
