Coolant leak
Old May 31, 2019 | 10:53 AM
dwruble23's Avatar
Coolant leak
I am having a small leakage of green coolant. By small, I mean fairly slow, its not spewing out. However, I cant seem to find the location for the leak. I am going to go to autozone and get the radiator pressure gauge/pump to see how fast the pressure drops. Any ideas on how to find the leakage spot and what else could potentially be?
Thanks
Old May 31, 2019 | 10:57 AM
What vehicle/motor do you have? Is this your 318 Duster?
Old May 31, 2019 | 10:58 AM
dwruble23's Avatar
I have a 1973 Duster with a 318 motor
Old May 31, 2019 | 11:03 AM
First thing I'd look at would be the water pump and see if its seeping out of the bottom behind the pulley.
Old May 31, 2019 | 11:08 AM
dwruble23's Avatar
Okay I will check that tonight after work. That would mean replacing the water pump wouldnt it?
Old May 31, 2019 | 11:20 AM
After that look at the thermostat housing, intake manifold at the heads, radiator hoses and radiator and heater core and hoses. It is possible that the heads are cracked and you might see water leaking from the castings or you have a head gasket issue. But this is a start on places to check for water. If it's the water pump you will need to replace it and it's not a bad job at all. If radiator or heater core cooling system sealer can work hoses need replacement.
Intake manifold gaskets leak over time as do thermostat gaskets so you will need to replace them at some point especially if a previous owner with little experience had gotten into the motor for any reason.
Good luck with your search
Old May 31, 2019 | 11:24 AM
If you can't find a leak try a bottle of Copper seal in the radiator, Copper or Silver.
https://www.zoro.com/bars-leaks-radi...QaAr_dEALw_wcB
Old May 31, 2019 | 11:27 AM
Just to add to the list... Freeze plugs?
????? Coming from the Front, Side's, Back?
Put a piece of cardboard down to locate the area also, if needed????
Old May 31, 2019 | 11:28 AM
And or shoot us some photos... to help you...
Old May 31, 2019 | 11:42 AM
Yep rusty freezplugs can get you and can be a pain to fix in the car.
tomcatx5
Apr 19, 2015 08:48 AM
Skynyrd
Sep 10, 2014 05:24 PM
Laura Cullen Reynolds
Nov 24, 2012 02:04 AM
olibass1
Sep 1, 2011 04:16 AM
77Aspen
Jul 11, 2011 02:17 PM
