Dan's 1972 Plymouth Duster
Old Nov 11, 2013 | 06:47 AM
  #31
I used Mr Gasket Extra thick. But then you will have to have longer bolts.
Or you can just grind the cover down if you want to use the thin gaskets...
Good Luck... Glad to help...
Old Nov 12, 2013 | 05:23 AM
  #32
62Furious's Avatar
You are moving right along and at the pace you are going summer is not too far away
Old Dec 26, 2013 | 07:53 AM
  #33
DanK's Avatar
I Degreased, clean and sanded the engine compartment this weekend. After sanding, I shot all the exposed metal with Self Etching primer. Ready for paint.... Once it warms up a bit. Hopefully it will get warm enough today.
Old Dec 26, 2013 | 01:31 PM
  #34
Wow...What a difference a little elbow grease does.Eh!!!..
Old Dec 27, 2013 | 09:48 AM
  #35
DanK's Avatar
Elbow Grease indeed! I painted it last night....
Old Dec 27, 2013 | 10:14 AM
  #36
I hope you used DP90LF....
http://www.tcpglobal.com/itemdetail....=PPG+DP90LF-GL
Old Dec 27, 2013 | 11:28 AM
  #37
I had that problem. Solved it by filing the edge of the valve cover & a little black paint
Old Dec 27, 2013 | 12:34 PM
  #38
Buffalojoe426's Avatar
Looking good!
Old Dec 28, 2013 | 04:05 PM
  #39
DanK's Avatar
Today, I made the dual hood scoops functional.
Old May 8, 2014 | 09:34 AM
  #40
DanK's Avatar
I haven't gone dead on this build, but it is going to take longer than expected. Wife's daily driver needed to be replaced, so I picked up a car payment... gunna slow the build down a bit. I'll keep posting as things progress.
Old May 8, 2014 | 04:49 PM
  #41
pro-tech's Avatar
Did someone change the K member my 72 Duster doesn't have that style motor mounts... It has the biscuit type..Bill
Old May 13, 2014 | 09:14 AM
  #42
DanK's Avatar
I don't know, it's probable that this is not the original K-member in my car. I think one of the previous owners had dreams of a drag car, but never finished.
handyrob1973
May 19, 2018 10:09 AM
72twister
Feb 6, 2010 05:17 AM
72twister
Feb 4, 2010 01:09 PM
72Scampman
Jan 30, 2010 09:49 PM
NJDUSTER340
Sep 3, 2009 11:05 AM
