1973 D100
Old Oct 30, 2019 | 01:08 PM
butch's Avatar
1973 D100
I have a 1973 D100 with a 318 engine, 1 barrel, and automatic......I have replaced all the electrical, carb, distributor, coil, plugs, and plug wires.....it cranks and runs just fine but when I try to ease on the gas it dies, it cranks right back up but then try to give it gas it dies again. I have also replaced the fuel pump and filter.....after repeatly doing this for 10 or 15 minutes you can finally get it to drive without dying....I replaced the auto choke and it seems to work fine …..does anyone have a notion as to what my problem is?
Old Oct 31, 2019 | 09:45 AM
Does the float bowl leak at all? Sounds like something stuck in there maybe...
Old Oct 31, 2019 | 11:55 AM
Check the Accelerator Pump in the Carb. Make sure it is Squirting a good stream of fuel...
Old Jan 22, 2020 | 12:55 PM
RCCadman's Avatar
First two things I would check are the accelerator pump in the carb and vacuum leaks.
dakota440
Dec 5, 2017 08:56 PM
chlngr1970
Dec 9, 2013 05:49 PM
cmetzbower
Aug 4, 2012 07:44 PM
TwistedWrenches
Mar 4, 2009 08:39 AM
mike639
Jan 31, 2009 10:14 AM
