1975 d200 issues
Old Jul 18, 2016 | 09:13 PM
mpask's Avatar
1975 d200 issues
Okay so I have a 1975 dodge d200 camper special with a 360. I have owned it for about 2 months now and never had issues until recently. It will randomly stall and sometimes be hard to start again. I am looking for possible answers and solutions. Thanks for all replies
Old Jul 19, 2016 | 06:33 AM
Plugged Fuel Filter or Fuel pump going bad...
Old Jul 19, 2016 | 01:32 PM
I agree, check the fuel system over.
Old Jul 19, 2016 | 03:18 PM
I'd be taking the fuel pump and running it in a bucket to do a timed volume test. Making sure to disable the ignition system before cranking. If it showed proper volume as per spec then the carb would be coming off for a look see and rebuild.
Now it could be something else but based on age and RV limited use sitting with an older gas tank, with your described symptoms, this is the place I would start.
Oh yes, and Welcome to the site!
Old Jul 20, 2016 | 07:09 PM
I would look for an air leak at the fuel tank ! Replace the rubber hoses !! Next time it happens check for spark ...
Old Jul 20, 2016 | 07:24 PM
mpask's Avatar
Update! So I replaced the fuel pump and fuel filters and it still does it. Seems to only happen when the engine gets hot. Plus it has been pretty hot where I live the past couple days so that isn't helping. Also i will add that it has a edelbrock 4 barrel carburetor and intake. Carb is a 1406 I am going to replace the rubber part of the fuel line tomorrow a wrap them in heat wrap as the lines were getting quite hot
Old Jul 21, 2016 | 03:26 PM
mpask's Avatar
Would it be the voltage regulator causing this problem or the distributor
Old Jul 21, 2016 | 05:21 PM
Did you confirm the fuel pump was bad before replacing? If you didn't it could still be a restricted fuel pick up in the tank. A proper and full diagnosis should be done before changing parts so you know that you have corrected the problem.
Old Jul 21, 2016 | 05:36 PM
mpask's Avatar
No I didn't confirm that but this only happens if I drive the truck for about 20 minutes and once I let if sit a while it will be fine again for another 10-20 minutes then same thing and right before it stalls there's a big backfire. The carburetor gets hot when the motor is running could this maybe be the issue. Like you can't even touch it it's that hot
Old Jul 23, 2016 | 04:46 PM
Douglas1300's Avatar
Vapor lock
I would look into vapor lock.
Old Aug 2, 2016 | 04:09 PM
Carb boiling over ? Try a carb spacer/insulator!
Old Aug 2, 2016 | 04:37 PM
mpask's Avatar
Yeah put a spacer 2" spacer in and rebuilt the carb. Still does it but not all the time. I'm going to go through all the wiring and look for a possible cause
Old Aug 6, 2016 | 05:30 PM
mpask's Avatar
So now I have noticed a some white ish smoke coming from his back of the engine when it's been running for a while
Old Aug 7, 2016 | 07:20 AM
That dont sound good? What is it?
Old Aug 7, 2016 | 07:38 AM
mpask's Avatar
Not sure what it is. It's not a lot of smoke it's only noticeable when you open the hood. Don't think it's an manifold leak since I recently changed the gaskets but maybe could it possibly be the head gasket?
Old Aug 7, 2016 | 07:42 AM
Maybe..... Or just a valve cover seeping a little and dripping on the exhaust manifold or pipe????? Check it out.... keep us posted....
Old Aug 7, 2016 | 07:44 AM
mpask's Avatar
Would that cause my issues I've been having?
Old Aug 7, 2016 | 09:25 AM
Head gasket would.... But not the stalling and hard start..
Old Aug 7, 2016 | 03:35 PM
mpask's Avatar
So it did it again today after not much driving and I took a plug out and checked for spark and there was no spark. But if it sits for a bit you can drive it a little more. Like a couple blocks hen same thing. Any suggestions. Maybe the distributor rotor and cap or the ignition coil
Old Aug 7, 2016 | 05:23 PM
sounds like it might be the ecu/module ??????
Old Aug 10, 2016 | 05:23 PM
mpask's Avatar
Thanks everyone for the replies I have finally gotten it fixed turned out to be the ignition control module
Old Aug 11, 2016 | 06:01 AM
Home run Bob!
Old Aug 11, 2016 | 07:39 AM
... I need to buy a lotto ticket !!!!!!
Glad you got it fixed... Make sure the box has a good Ground to the body...
Old Aug 11, 2016 | 07:50 AM
  #24
Are you saying luck had something to do with it, I thought you were just good.
Old Aug 11, 2016 | 02:42 PM
  #25
Shhhhhhhhhhhhhhhh....lol
Old Sep 18, 2016 | 12:15 PM
  #26
mpask's Avatar
what would cause this part to keep goin bad. I have to change it again as the problem is happening again
Old Sep 18, 2016 | 12:40 PM
  #27
what are you putting in for parts, mopar, napa etc.?
Old Sep 18, 2016 | 05:46 PM
  #28
Check or change the Dist. Pick-Up.... Also make sure you are using the write ignition coil..
Old Sep 18, 2016 | 08:13 PM
  #29
mpask's Avatar
I'm not sure on he brand of it. would a subwoofer cause this problem
Old Sep 19, 2016 | 06:20 PM
  #30
Not that I'm aware of...
