1980 dodge w150 head
Old Oct 6, 2015 | 05:21 AM
tadmorris95's Avatar
I have a 1980 dodge w150 with the la 5.9 360 in it i took off my heads and noticed theres a hole in them shaped like an upside down u with a rectangle in the middle of it. It was completely clogged full of junk. I cant seem to figure out where it goes or what its supposed to do. Any help would be appreciated
Thanks,
Tad
http://www.rockauto.com/catalog/more...nid=527&jpid=0If you go threw the pictures on the link it shows the hole im talking about.
Old Oct 6, 2015 | 05:39 AM
Thanks,
Tad
That would be the exhaust crossover, used for heating the base of the carb.
Old Oct 6, 2015 | 05:43 AM
Okay my intake manifold doesnt have a spot for it. Should it? Or should it just be open?
Old Oct 6, 2015 | 05:44 AM
welcome to the forum, performance manifolds don't. it's just fine.
Old Oct 6, 2015 | 01:49 PM
Drag Pak's Avatar
Some gasket kits come with "block off " plates for the heat passages, or you can make your own from some thin tin(soup can).
Old Oct 6, 2015 | 01:50 PM
It sent hot air to the EGR system / engine warm up.. Always got clogged with carbon buildup Fine to leave it open or you can block it closed
William Carroll
Jun 19, 2013 05:40 PM
Dominic Torreto
Oct 11, 2012 09:10 AM
bremereric
Aug 5, 2011 10:00 PM
richinny
Jul 1, 2008 03:48 PM
summerj
Feb 6, 2008 08:34 PM
