1982 Dodge D150 D-150 Fusible Link Help!!
Old Nov 1, 2012 | 08:57 PM
dwone555's Avatar
My Dodge D-150 V8 blows the Orange fusible link when the engine is started. At first it blew when trying to start it. I re-spliced (notice the blue barrel splice in the picute) and when it started this time, it again blew the same orange link. What causes this? How would I troubleshoot this?
I have confirmed it provides power to the Dark Blue wire that enters the bulkhead under the dashboard.
Please help! See attached pictures.
Attached Thumbnails 1982 Dodge D150 D-150 Fusible Link Help!!-capture.jpg   1982 Dodge D150 D-150 Fusible Link Help!!-capture2.jpg
Old Nov 2, 2012 | 05:38 AM
Gorts 5th's Avatar
Smile
i think wat your suffering from here is old wires usually a fried link is a sign of a short finding it is the trick ive always hated finding shorts they are not easy check over all wires involved with the ignition system the blue wire is a main power supply to the circuit
good luck
Old Nov 2, 2012 | 09:34 AM
There may be a short, or the charging system may have a problem with a massive overcharge condition, OR the bulkhead connector may be AFU, causing heating, etc.
I would do two things:
Temporarily wire in a 30A fuse and disable the alternator
To eliminate the alternator output and an overcharge condition, try pulling the regulator connector off and start. If the fuse blows, replace it and try starting the engine with the alternator belt removed. Don't run it long this way, a minute or two when cold won't hurt The reason for doing this is that you may have a wiring problem or internal alternator problem (One brush shorted to ground, example) causing the overcharge
If the above does not improve things, look the under--hood wiring over and "think." Has anything been added electrically which requires switched 12V? The "ignition run" buss IS NOT FUSED except for the fuse link, which is darn poor protection.
The "ignition run" buss (known as IGN1) feeds power in run ONLY (not accessory) to the instrument cluster for warning lights, temp and fuel, and oil pressure if equipped. It comes through the bulkhead and supplies
the regulator IGN terminal
the blue alternator field connection
the ignition system
electric choke if equipped.
On some vehicles, some smog doo dad.
How about INSIDE the truck? Anyone added a tach, gauges, other electrical accessory?
READ (please) this excellent MAD article. Even if you are not contemplating bypassing the ammeter, this article points up the pitfalls of all these vehicles
Scroll down the page and examine the simplified diagram. Notice the "welded splice" in the black wire. This is a factory splice in the black ammeter wire, taped up in the under--dash harness. Branched off of this ALL UN--FUSED!!! is headlight switch power for the headlights only, power to the ignition switch, and a couple of other places.
Notice the photos of typical damage to the bulkhead connector. When these connections deteriorate, they build heat, which gets worse and worse.
98 SNAKE EATER
Jan 28, 2018 08:03 AM
mirada82
Feb 24, 2012 01:49 PM
Grocery_Getter
Jan 14, 2010 02:33 PM
1982dodgeram
Jan 12, 2009 08:00 AM
1982dodgeram
Nov 26, 2008 02:27 AM
