2wd Ramcharger build?? Need input.
Old Sep 15, 2015 | 07:54 PM
76DartSport's Avatar
Im looking into building a mid seventies ramcharger into a 2wd cruise machine. This said, is there anyone out there that can tell me what frame might work for this project? shortbox? Was there any 2wd ramchargers made? that would save me some time and effort. ive owned a 76 stepside, and a 77 shortbox. im looking to build this as a cruiser for myself , with the intention of maybe passing it to my daughter when shes old enough. any input would be greatly appreciated. Thanks ahead of time.
Old Sep 16, 2015 | 09:50 AM
I think I've seen pictures of one on this forum in a thread on dropped pickups trucks.
Sounds like a cool project!
Old Sep 16, 2015 | 09:58 AM
One thing if you cant find one you can build one, the frame is mild steel so it can be cut and a 2 WD front can be swapped with competent welding, triangulated four link in the rear and 4 air bags, late Hemi, COOL!
I want one.
Old Sep 17, 2015 | 08:28 AM
DDodger's Avatar
Yes there were 2wd ramchargers, but I have no idea what might be involved in conversion.
You will either have to find a junker to convert the front suspension, or put a "clip" under it out of something else
You will need a 2WD transmission setup, and have a new driveshaft made. So your present transfer case / transmission is "a lot of useless."
If you can find a core transmission, you can change the mainshaft and tail housing of the present trans
Old Sep 20, 2015 | 10:28 PM
DodgeAddict's Avatar
There weren't many 74-80 2WD made Here's my old 84 2WD I'd sit the early model on this frame You will gain a 35-6 gallon gas tank along with 2WD
Old Jan 22, 2020 | 02:24 PM
RCCadman's Avatar
Old thread, I know, but adding in case someone in the future wants to know.
Yes, there were 2WD RC's made. I have a 77. The pic below is mine with a 3" body lift that will be removed.
Also, the Ramchargers were made with a D100 frame shortened 9"
Old Jan 23, 2020 | 09:46 AM
Putting it back to stock? What lift is on it? Brand, I mean...
Old Jan 23, 2020 | 09:59 AM
RCCadman's Avatar
I have no idea what brand lift is on it or how long its been on there. I just bought it a few months ago. I can say that it is a body lift of 2-3 inches. It is a 2WD that I plan on bringing back to stock height and then using B series van lower front control arms to drop the front 2-3 inches. Ramchargercentral.com doesn't have much information on 2WD front suspension, so I thought I would mosey over here and see what's what. lol
Leem
Sep 28, 2019 06:48 PM
Skwerly
Apr 9, 2014 02:52 PM
dodgeboy92
May 7, 2013 07:04 PM
plymouthrr1985
Apr 12, 2009 08:04 PM
