318 d200 electrical issue ?
Old Dec 30, 2018 | 02:35 PM
Rich Markiewicz's Avatar
Hi everyone long story short I have a 75 d200 5.2 l that has been sitting for the past month or two . The truck will not crank unless I use a screw driver to jump the multi function relay . Also none of the accessories work. When I replaced the exhaust a while back the starter had to be removed and the transmission linkage may be mixed up . Battery, fuses, relays test good , I am at a loss of what else could be the issue
Old Dec 30, 2018 | 04:27 PM
There is a bulkhead connector on the drivers side of the firewall, my suspicion is that there is a problem with it. It is plug in for the front wiring harness so you need to unplug it and clean all connections.
Monty.Smith
Feb 23, 2022 04:50 PM
cuda341
Sep 9, 2018 06:49 AM
hkestes
Sep 7, 2018 08:51 PM
gwsharklover23
Apr 18, 2018 12:55 PM
79pw
May 21, 2017 09:49 AM
