82 D 150 door stuck shut
Old Feb 27, 2020 | 12:26 PM
Paul McCoid's Avatar
My 82 has the drivers door stuck shut, I've taken off the panel everything seems to be hooked up and moving but the door won't open.
any ideas on what I can do?
Old Feb 28, 2020 | 03:51 PM
Spray the latch.... Make sure the lock and unlock rod lever is in the unlock position.... Pull the door opening lever to the open position and kick it open from the inside. Replace the latch if you cannot clean it.
If you cant do that... See if the Striker bolt is accessible and unloosen it from the inside of the door panel. But if it is covered, Good luck.
Old Mar 1, 2020 | 01:14 PM
Spray the handle too....
Old Mar 5, 2020 | 09:26 AM
longtimecoug's Avatar
thanks for the advice, the door is now open and working fine. it just needed to be lubed up after so many years
Old Mar 6, 2020 | 10:13 AM
Good Deal..... Happy Cruising !!
Anthony Turner
Nov 4, 2017 10:47 AM
LW Hiway
Dec 28, 2013 09:08 AM
linusj
Jul 6, 2013 06:55 PM
Damtom
Nov 25, 2012 09:54 PM
CoogarXR
Dec 25, 2009 04:39 PM
