92 w-150 dodge truck 318 mag
Old Feb 16, 2011 | 04:22 PM
cide's Avatar
i need some help. ok,my trucks has gotten to where its cutting off only when i put it in drive. not sure if its something to do with the transmission or what. a few time when trying to crank it back up it had lost fire to the coil.so i check the pick up coil on the fly wheel all good and the pickup in the distripture.all seam to be good.and plug up good.not to sure what ellis would cause it to shut off like it does.The truck been shitting for about 3 years and before it was park i replace all the sensor, fuel pump,even has a rebuild trans in it with new torque.[could it be a vacum issue] trans is a 46r od 4x4
Old Feb 17, 2011 | 05:59 PM
cide's Avatar
ok guys,it seems to be 2 ground wire. one brook at the motor to the firewall and the other was not hook up at the batteries ground post.causeing low votage. so i hope this will be helpful on down the road always check them old ground wires.
Old Feb 18, 2011 | 03:22 AM
That does make sense. In the late 80s chrysler starting putting a code in the car's computers that told it to shut down the motor if it did not see enough current.
Good find!
tcobra29
Jul 29, 2014 03:29 PM
bigroodawg
Dec 13, 2012 04:34 PM
bigroodawg
Nov 10, 2012 09:42 AM
Dave E
Sep 4, 2009 03:52 AM
mopar230cudaaar
Dec 8, 2008 07:11 PM
