Brake pedal difference 78 to 93 model
Hey guys, I have a problem. I have a 78 D100 and a 93 W250. The braked pedal in the 93 sits quite a bit higher than the one in the 78. I looked and measured them both. The 93 pedal is a bit shorter and is curved up toward the driver a bit more than the on one the 78. I have an injury that gives me problems with my feet and lower legs. I can drive the 78 quite well, but the 93 pedal being so high makes it difficult to hit the brake, and I am worried I might miss it in a panic situation. I am wondering if a brake pedal from an earlier model like the 78 would be a direct swap. Has anyone else attempted this? I would like to know what year Dodge changed the style of pedal, so I can search for a used one. I am ASSUMIMG it would be when the cab was re-vamped between 80 to 82, but not sure. Anybody know? Have a good used pedal for sale?
Thanks
Thanks
Easy modification. The pedal hangers are the same. However, for the booster push rod, the 93 uses a welded on stud and clip. The 80 uses a special through bolt. That special bolt was too big for the 93 booster rod. However, the hole in the pedal was drilled the right diameter to tap for 5/8 SAE fine threads. I used a 5/8"- grade 8 bolt with washers for spacers to make it work. Threaded the bolt into the tapped hole, and ran a poly lock up the thread to jam it so could NOT loosen up.
BHayes
May 15, 2013 03:08 PM
