Brake pedal difference 78 to 93 model
Old Mar 19, 2018 | 08:12 AM
Big Bad Dad's Avatar
Hey guys, I have a problem. I have a 78 D100 and a 93 W250. The braked pedal in the 93 sits quite a bit higher than the one in the 78. I looked and measured them both. The 93 pedal is a bit shorter and is curved up toward the driver a bit more than the on one the 78. I have an injury that gives me problems with my feet and lower legs. I can drive the 78 quite well, but the 93 pedal being so high makes it difficult to hit the brake, and I am worried I might miss it in a panic situation. I am wondering if a brake pedal from an earlier model like the 78 would be a direct swap. Has anyone else attempted this? I would like to know what year Dodge changed the style of pedal, so I can search for a used one. I am ASSUMIMG it would be when the cab was re-vamped between 80 to 82, but not sure. Anybody know? Have a good used pedal for sale?
Thanks
Old Mar 19, 2018 | 07:14 PM
The fix might be just a shorter pedal to master pushrod length.
Old Mar 20, 2018 | 02:12 AM
NO. It is a different shape and length of the pedal arm itself.
Old Mar 20, 2018 | 05:07 AM
Pics of the difference. See the curvature at the bottom. Plus the 78 is a bit longer, which drops the pedal down lower.
Attached Thumbnails Brake pedal difference 78 to 93 model-dsc00528.jpg   Brake pedal difference 78 to 93 model-dsc00532.jpg
Old Mar 20, 2018 | 05:37 AM
Well, excuse me!
Old Mar 20, 2018 | 07:49 AM
Well, excuse me!
Sorry, didn't mean to sound like I was yelling. Mis-typed the no word in all caps...
Old Apr 12, 2018 | 01:17 PM
Well, I bought a pedal from an 80 Ramcharger on ebay and swapped it out in the 93. The Ramcharger pedal is about 3/4" longer than the 93 pedal which moves it closer to the floor. That helps!
Old Apr 14, 2018 | 07:04 AM
Thats good to know.... Was the Bolt size the same for both pedals. Or did you have to modify the pedal hanger?
Old Apr 15, 2018 | 04:57 AM
Easy modification. The pedal hangers are the same. However, for the booster push rod, the 93 uses a welded on stud and clip. The 80 uses a special through bolt. That special bolt was too big for the 93 booster rod. However, the hole in the pedal was drilled the right diameter to tap for 5/8 SAE fine threads. I used a 5/8"- grade 8 bolt with washers for spacers to make it work. Threaded the bolt into the tapped hole, and ran a poly lock up the thread to jam it so could NOT loosen up.
Old Apr 15, 2018 | 07:31 AM
Awesome... Glad to hear that worked out for you... I know that feeling of not being able to lift you leg up so high to get to the pedal... Great update and information....
BHayes
May 15, 2013 03:08 PM
cudagecko
Apr 20, 2013 08:24 PM
cudagecko
Apr 19, 2013 02:54 PM
tcherrone
Apr 15, 2011 05:03 AM
1966DartConvertible
Sep 21, 2010 06:28 PM
