Cheap work truck
Old Aug 10, 2017 | 08:35 PM
Cdrift's Avatar
Cheap work truck
So I just picked up an 86 dodge 1500 for a daily driver / work truck
All the upgrades that I will do are to make the truck better on the cheap, so I am not afraid of crossing any lines
So 1st upgrade since it came with straight pipes I needed a muffler, I found this sweet Toyota muffler for 20$ off of a Tacoma. Thinking I should put a trd sticker on it
2nd upgrade was the battery box, the battery is just held in place by 2 bungee cords so I bent some scrap 90 pieces of scrap steel I had lying around and bolted them to the original box. More pics soon, got dark
Attached Thumbnails Cheap work truck-img_0397.jpg   Cheap work truck-img_1587.jpg   Cheap work truck-img_1590.jpg   Cheap work truck-img_1591.jpg
Old Aug 13, 2017 | 03:47 PM
Cdrift's Avatar
So this is the carb on it. Might be a stupid question, but is it stock? Im thinking not, but I have no idea. If someone could tell me what type of holly carb it is and is it good for a setup of mpg or not
Attached Thumbnails Cheap work truck-img_1599.jpg   Cheap work truck-img_1600.jpg
Old Aug 14, 2017 | 10:15 AM
MoparnewbieW150's Avatar
Does that truck have a/c ?
Old Aug 14, 2017 | 08:40 PM
Cdrift's Avatar
Yes it does
The plan will be to bypass the ac condenser since the ac doesn't work, also looking into an electric fan also. I was looking at the 16" single fan from flex a lite, should work.
Old Aug 15, 2017 | 12:39 PM
I guess I'm going to 86 the a/c as well,maybe hook it back up in the spring... can you upload a pic of the power steering pumps mounting brackets for me?i think mine had a small bracket hooked to the main bracket... I'm starting to panic.
Old Aug 15, 2017 | 03:43 PM
Cdrift's Avatar
Pics of motor and lines. I was hoping I could go straight from the crank to the alternator
Attached Thumbnails Cheap work truck-img_1604.jpg   Cheap work truck-img_1601.jpg
Old Aug 16, 2017 | 08:31 AM
I'm about to put all that back in today,I'll post a pic of the brackets I have left over,maybe that will jog a memory or 2.
Tiretrack
Jul 12, 2010 02:52 PM
ef8340
Dec 17, 2008 12:07 AM
70cudas
Nov 13, 2008 10:22 AM
7thgeneral
Jul 25, 2008 09:44 PM
