DIY Suspension or pay someone
Old Mar 19, 2021 | 11:29 AM
Tau511's Avatar
Hey guys,
The suspension in my 75 with 1979 3/4 ton axles is horrible. It has a block 3 in lift that's pretty worn out and even has some exciting wood shims slipped in there.
What do you think, it seems pretty straight forward to buy a new kit and do it myself but I've not done any 4x4 suspension work before. Any of you all DIY suspension guys?
I've done front end stuff on an early 70s Nova, those coils seem harder to work with than leaf springs.
Only motivation is money.
Old Mar 19, 2021 | 01:38 PM
Buy good parts as complete kit as you can and do it yourself. Rear suspension is easier than the front.
If you need to spend a little on tools or equipment that you will have for ever thats better than giving the to someone else to do it.
That's why I have a garage full of tools and equipment.
Old Mar 19, 2021 | 02:01 PM
Tau511's Avatar
Cheers, thanks for the encouragement.
Old Mar 20, 2021 | 10:34 AM
yessir, it's easier than you think. the biggest tip ever? PB Blast everything daily a week before you tear down. you'll thank yourself.
Old Mar 20, 2021 | 08:14 PM
Tau511's Avatar
Good tip! I'll follow through with that after I pick my kit out. Anyone have anything good to say about any of the kits out there?
Old Mar 20, 2021 | 08:50 PM
xaza's Avatar
Yeah the biggest issue is getting the old bolts out. PB blaster is not that good. I use aero kroil, it gets much better penetration. If the wood shims are in the front then make sure and check your pinion angle before removing anything and make sure you get it back to the same, without using wood preferably.
29
Apr 28, 2015 06:17 PM
catchmeifyoucan
Aug 16, 2014 10:18 AM
badassdart6727
May 25, 2011 09:58 PM
Rex 360
Feb 9, 2011 09:29 PM
Mango
Sep 13, 2010 06:52 PM
