Electrical issues
Old Oct 28, 2019 | 01:40 PM
VaPWag's Avatar
Electrical issues
I need help finding the root of my issue, out of nowhere all gauges dropped (except speedo and amp) no turn signals (4way works) and one normal low beam but switch to high and both extremely dim, also high beam indicator in dash stays lit no matter the selection. I've checked a few grounds to no avail but will be doing more checking when I get a day, just curious if anyone could pin point an area to check. Thanks
Old Oct 28, 2019 | 04:04 PM
Check the wiring for the dimmer switch... Sounds like it might have rubbed threw and is shorting out on the floorboard.
Old Nov 11, 2019 | 03:49 PM
VaPWag's Avatar
update: checked the hi/low switch no problem I did end up replacing some of the fuses (all looked good before) and the one for turn signal was not blown but has a bad connection, seems the terminals are loose, I can get it working and gauges come back but still have a headlight problem. Will be messing with that issue this weekend possibly ( no garage and dark before I get home ) hopefully get this figured out I like to drive her in to work but my OCD goes nuts with light out.
crwchf16
Jan 22, 2018 08:55 AM
D100941
Oct 23, 2017 05:47 PM
val1550
Jul 18, 2013 12:17 PM
nesparky
Dec 12, 2011 07:05 PM
thumpn
Feb 13, 2007 11:03 AM
