Pistons Hitting Crank counterwights
Old Jun 1, 2022 | 10:32 PM
KhandunSingh's Avatar
I’ve been on a Journey rebuilding a 318. got it machined ready to go and i put the crank in which is a 3.58Inch stroke and OEM style pistons but the pistons seem to be hitting the counterweights and i was wondering if anybody knows of On the shelf pistons that will help get rid of this issue. I’m also putting Edelbrock performance RPM cylinder heads on it. anything helps thanks.
Old Jun 2, 2022 | 08:59 AM
Are you trying to use stock 318 pistons? If so you need pistons specifically for the bore and stroke how along with the deck height of the block you are using. The Edelbrock heads are ok there are better but they are ok, the thing you need to do is have the heads gone over by a competent rebuilder before using, check areas like guide clearance and have a performance valve job done.
Try Keith Black or ICON for pistons but I’ve heard off the shelf pistons are hard to get at this time, custom might be the best way to go fo now.
Old Jun 2, 2022 | 12:26 PM
My bores are +0.40 over. i don’t know about all that other stuff so i’ll have to get somebody that knows
Old Jun 2, 2022 | 07:23 PM
Give these guys a call if they can’t help you no one Can.
Hughes Engine’s, sorry I couldn’t get the link to copy so you will need to google it.
Old Jun 4, 2022 | 09:39 AM
Here you go buddy !!!!!
Hughes Engines
So you are using a stroker crankshaft?
Old Jun 4, 2022 | 10:36 AM
That the one, I got this damn I phone, never again….
Old Jun 5, 2022 | 09:44 AM
All I can say is it has been a big learning curve! Hasn't it....
Old Jun 5, 2022 | 11:54 AM
Grandson wanted an iPhone for Christmas so I got him one I needed a phone so I got one also. Damn I want my Samsung back.
skimoe55
Sep 16, 2018 04:28 PM
Davejmm
May 15, 2017 02:40 PM
DropTrooperZim
Jun 15, 2016 02:46 PM
yuppy
Apr 4, 2014 11:25 PM
mbalser1
Dec 18, 2009 05:50 PM
