Trouble removing pulley from power steering pump
Old Sep 6, 2019 | 12:11 PM
okrobie's Avatar
Hi all, This truck ('89 Dakota 3.9L) came without a power steering pump so being on a budget I decided to buy a used one and install it myself. First problem: The used one came with a serpentine pulley and I need a V belt type. I have a replacement V belt pulley, but I cant remove the old one. It has an Allen bolt .at the center of the pulley facing in. I put the pulley in a vise and it is a 3/8" Allen drive. I tried a 3/8" air drive, but that didn't budge it. I have an Allen wrench so I put that in and even using a 4 foot persuader I couldn't move it. I sprayed it with Blaster penetrating oil and let it sit overnight but that didn't help. I could apply heat or I could drill it out, but I thought I would ask you guys before I make a mistake. Thanks for any Ideas. Regards
Old Sep 7, 2019 | 10:51 AM
maybe a local shop could do it for a few bucks?
Old Sep 8, 2019 | 03:25 AM
okrobie's Avatar
Thanks Skwerly, hat's a good idea but as I mentioned earlier I'm on a budget, so there isn't any money to do that. I think I will now try heat. I have an acetylene torch, so why not? I'll let you know how it goes. I'll do it Monday.
Old Sep 8, 2019 | 09:19 AM
yeah, i hadn't realized there was NO budget haha... heat is always an option!
Old Sep 8, 2019 | 09:55 AM
fivepoint's Avatar
Be very careful with the heat. You don't want the heat to ruin the rubber shaft seals. Are you sure the bolt is not left hand thread?
Old Sep 8, 2019 | 08:13 PM
okrobie's Avatar
I tried it both ways.
frank220
May 27, 2018 08:08 PM
Polara-Lee
Oct 22, 2012 02:30 PM
Polara-Lee
May 4, 2012 10:46 AM
Rosco83522
Jun 22, 2011 02:42 PM
sixfive407
Sep 24, 2010 05:13 PM
